turbo gsr: Oil keeps repeatedly gettin on sparkplugs
Old May 12, 2006 | 01:37 PM
ownedbyvtec's Avatar
Default turbo gsr: Oil keeps repeatedly gettin on sparkplugs
for some odd reason oil keeps gettin onto my sparkplugs, ive already changed the rubber rings around the vale cover twice within in the last year. it solves the problem temporarily but then start up again after a few months. Any ideas or comments on what it may be would be great
Old May 12, 2006 | 01:39 PM
raene's Avatar
Default Re: turbo gsr: Oil keeps repeatedly gettin on sparkplugs (ownedbyvtec)
How's your PCV system?
Old May 12, 2006 | 06:02 PM
i2un's Avatar
But did you change both the upper and lower plug seals?
Old May 12, 2006 | 10:56 PM
darkdayz's Avatar
Default Re: turbo gsr: Oil keeps repeatedly gettin on sparkplugs (Emiken)
Upper and Lower spark plug seals????yeah I might need an answer on this one myself
Old May 13, 2006 | 07:29 AM
97turboteg's Avatar
Default Re: turbo gsr: Oil keeps repeatedly gettin on sparkplugs (darkdayz)
headgasket?
Old May 13, 2006 | 08:09 AM
inspyral's Avatar
I used to have that problem, and before I got around to getting new plug tube seals, I ran a bead of RTV/silicone gasketmaker stuff under each of the seals. It worked great until I finally got new seals about 6 months later. I would maybe try that and see if your problem persists. At least it'll tell you whether oil is seeping in under the seals or if you have a different problem.
Old May 13, 2006 | 05:33 PM
Default Re: (inspyral)
ive only changed the four big ones which go aorund the valve cover. i didnt reseal the large rubber trim which goes in bw the valve cover and head. could that be a probalbe cuase?
Old May 13, 2006 | 08:57 PM
93c1sol's Avatar
Default Re: (ownedbyvtec)
umm...i don't believe there are any lower seals......there is the valve cover gasket and the 4 spark plug round seals. I don't believe there are any other gaskets that would leak onto the spark plugs. Headgasket would not cause that problem either. Just replace the valve cover gasket and 4 spark plug gaskets.
Old May 15, 2006 | 10:16 PM
Default Re: (93c1sol)
some1 mentioned some gorments around the rockerarms which may lead to this problem also? anyone have any furhter info on this subject?
Moo Sid
Oct 30, 2017 09:26 AM
relentlesstech
12
Feb 3, 2014 07:56 PM
luckypon7
Jul 12, 2005 01:33 PM
Witty
Apr 14, 2003 10:28 AM
EGchino
Jan 20, 2003 03:55 PM
