remote turbo(non-honda)
Old May 12, 2006 | 09:05 AM
ThefirstPACT's Avatar
Default remote turbo(non-honda)
So my buddy at work wants to turbo his tacoma! We're only looking for around 5 psi! Now I've had a turbo honda and oil lines were easy on that, but how would I go about setting up lines for a remote turbo set-up? Any info would be great! I know there are kits but we're gonna put it together ourselves...much cheaper!
So someone point me in the right direction!
Thanks in advance!
Dutch
Old May 12, 2006 | 09:44 AM
Azn Kenny's Avatar
On F-Body's I've seen remote turbos mounted near the rear drive shaft, sucks to have to run piping all the way back there though.
Old May 12, 2006 | 09:53 AM
Default Re: (LS-N)
are you talking about oil lines...
Old May 12, 2006 | 09:55 AM
crxnj's Avatar
Default Re: (ThefirstPACT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about oil lines...</TD></TR></TABLE>
hes talking about the charge piping,,but the oil lines would suck to...and im assuming you would need some kind of pump for the oil with lines that long..
ive never seen under the hood of those tacomas,,there's no room at all in there?
Old May 12, 2006 | 09:59 AM
jpenman50's Avatar
Default Re: (Mr.speaker)
http://www.ststurbo.com ................ You can purchase everything needed to do the job... Rick is a great guy and his kits work great!!!!!!
Old May 12, 2006 | 11:03 AM
jamheg1101's Avatar
Default Re: (jpenman50)
You will just run the feed line like normal all the way back to the turbo. For the drain line you will want to get a pump, such as the one tilton makes and there are a few others. You will just run the pump inline on the return line.
Old May 12, 2006 | 11:19 AM
Default Re: (jamheg1101)
The charge pipes are pretty easy and straight forward....I was just concerned about oil feed and return lines! Anyone have a link to the return pumps?
Also I am NOT looking to buy a kit..way over priced! Looks to be pretty good kit though!
Dutch
Old May 12, 2006 | 11:36 AM
emotionisdead's Avatar
Very Emergency!!
here, this should help:
http://www.ststurbo.com/tacoma
here is the direct link to it, one bad *** tacoma for sure!!
Old May 12, 2006 | 12:43 PM
nerdsports's Avatar
i believe there was a thread about this a while ago.
for oil feed, i dont think it would be anything different from something like a honda. as for the return, they use a pump. their pump, however, uses a failure/warning light. if the pump dies or begins to die, a light mounted in the cabin will warn you before the oil backs up and screws up your seals.
in that thread, they posted some cheap pump alternatives, but none had a warning feature.
Old May 13, 2006 | 10:54 AM
Default Re: (nerdsports)
thanks for the info Nerdsports! Anyone have any links to a oil pump that is really good!
Dutch
Old May 13, 2006 | 02:37 PM
BB6-213's Avatar
Post pics if you guys do it, I have always wanted to boost my Tacoma.
purpleh22
Feb 20, 2006 06:56 AM
b4tn
Dec 30, 2004 04:00 PM
del slw
Dec 29, 2004 05:54 PM
b18civicek850
Apr 11, 2004 10:00 AM
