cleaned Iacv....still bouncy tach +some
Old May 11, 2006 | 10:19 PM
Silent_Destruct's Avatar
Default cleaned Iacv....still bouncy tach +some
alright so the first time i cleaned the iacv the bouncy idle (1500-2000) stopped....it came back again and i cleaned it again and it did nothing. what else could it be? also it seems sometimes when i first start the car for the day (like after its been sitting for about 6-8 hrs) itll seem like its not getting fuel or sputter, but then i just give it throttle and it goes back fine, almost seems like its going to die but never does.
also sometimes i get an idle under 500 and feels like its going to kill but right when it feels like its going to die, it kicks in and bounces back up to 1000 and settles to 700 like normal....weird.
also ive done a complete tuneup excluding fuel filter (could that be problem? possible?) because autozone doesnt have it in.
thanks guys
Old May 11, 2006 | 10:26 PM
tegman85's Avatar
cel on?
Old May 11, 2006 | 10:37 PM
sik96teg's Avatar
Default Re: (tegman85)
I would replace fuel filter and check timing. If that dont work maybe valve adjustment. Those are the things i did when my idle was acting up when i thought it was my iacv.
Old May 11, 2006 | 11:15 PM
elrandeeto's Avatar
Default Re: cleaned Iacv....still bouncy tach +some (Silent_Destruct)
the bouncy idle is probably being caused by the fitv it sits right under your throttle body . there are 2 coolant lines going into it remove those . Then remove 3 10mm bolts and remove it . On the back of it facing the firewall , there are 2 screws holding a cover on remove it . Inside there is a whiteish plastic screw in there , you can remove it and clean everything or just tighten it down , more than likly its backed itself out its a common problem . This should fix your bouncing idle goodluck
Old May 11, 2006 | 11:49 PM
project 2two9's Avatar
check all your sensors and make sure all the vacuum lines go where there suppose to go...
Old May 12, 2006 | 04:07 AM
G2TegGuy's Avatar
Default Re: cleaned Iacv....still bouncy tach +some (project 2two9)
Also check your idle adjustment screw. I had the same problem and all it took was a half turn and voila.
Old Jul 19, 2006 | 11:13 AM
WHAT TEH's Avatar
...follow-up?
_taF
phatbuddha
May 20, 2013 10:46 AM
96b18c
Nov 19, 2009 08:59 AM
pjr710
12
Jul 5, 2008 09:03 PM
maxxdout
Jun 21, 2002 06:04 AM
