low idle ...
low idle ...
i just changed my fuel filter .. and my car seems to be running smoother.. but my idle is pretty low .. like ~400. i'm going to clean out my iacv this weekend when i install my turbo kit, but could anything else cause it to idle lower? could i have fuked up when i installed my filter?
Re: low idle ... (pjr710)
Not unless you took off your old filter with a hammer and a prybar. Smells like your IACV could be stuck closed from dirt and filth. 4-450 RPM is base closed throttle idle(IACV not contributing to idle control).
Re: (Hanmin)
Could be the ECU relearning fuel trims possibly from proper fuel pressure or you simply have a bad/temperamental IACV. In all honesty, sometimes my EM1 hits that low of an idle. Drops to about 450 RPM, then jumps back up to 750-800, and i'm too cheap to spring for a 175$ part that I sprayed out countless times with cleaner when the car does just fine with the 220k that it has on the clock. I wouldn't go turning screws on the TB though. It's not a carb.
Re: low idle ... (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote">Not unless you took off your old filter with a hammer and a pry bar. </TD></TR></TABLE>
LMAO
sorry just found it funny thats all
however with respect too your problem you could mess with the suggested quote or just up the idle air on the TB
LMAO
Re: (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V »</TD></TR><TR><TD CLASS="quote">Could be the ECU relearning fuel trims possibly from proper fuel pressure or you simply have a bad/temperamental IACV. In all honesty, sometimes my EM1 hits that low of an idle. Drops to about 450 RPM, then jumps back up to 750-800, and i'm too cheap to spring for a 175$ part that I sprayed out countless times with cleaner when the car does just fine with the 220k that it has on the clock. I wouldn't go turning screws on the TB though. It's not a carb. </TD></TR></TABLE>
its not a carb.... its a throttle body....
Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote">
its not a carb.... its a throttle body....</TD></TR></TABLE>
OMG thats your reasoning
it is controlling idle air speed which in tern controls the idle marker
well i'm lazy .. and i dont feel like cleaning out ht iacv right now .. it idles fine like 70% of the time .. then like 30% its a little lower .. so i'll just wait till i feel like cleanin that **** and do it up
maxxdout
06-21-2002 06:04 AM
