Inline Pro T3 manifold with 3" DP??? Can it be done???
The current inline Pro setup Im running has the cold side on the passenger side. I wnat to know if anyone has switched the turbo so the cold side is on the drivers side and run a 3" downpipe. The IP setup isn't bad but I would like to go 3" DP instead of the 2.5.
Anypics or advice would be appreciated. Its a T3/T4 fivebolt. My friend is custom welding the DP so I'm not asking about off the shelf DP's working.
https://honda-tech.com/zerothread?id=1619722
Check out the adapter I made in that thread. If you can weld or know someone, get a 2.5" sch10 or sch40 elbow & get 2 T3 flanges, then fab up an adapter putting a 15* angle on the turbo and kicking the ex housing out.
Of course it can be done. Check out my car https://honda-tech.com/zerothread?id=1532363 Im running a Inlinepro t3 manifold, precision gt35r, and a 3inch dp.
to Inlinepro for a decent manifold at a great price.
Yes, and as for reversing the turbo so cold side is on the driver side yes you can do that as well. Mine fits no prob with no A/C. I am running a Fluidyne Civic radiator and my DP
is a 2.75" (just to clear the RAD) into a 3"
dont do that hi profile did. the turbo more then likely wont last long as oil wont drain well otu of it. if you know a thing about manifolds, you want to keep the turbo as level as possible.
Thanks for the responses guys. Especially SIKITR01-248, those pics said a thousand words. Excellent, I'm set now.
YAGGA_YA
Feb 11, 2011 02:01 PM
cuin9sec
Jan 25, 2006 04:51 PM
lilxvtecxpwr
Dec 9, 2002 06:13 AM
