how do i identify a y8 tranny
Old May 10, 2006 | 07:09 PM
IVAN93EG's Avatar
Default how do i identify a y8 tranny
getting a y8 tranny this friday and im not sure how to tell if it"s an ex tranny.mine took a fat turd wednesday.
Old May 10, 2006 | 07:21 PM
DFW's Avatar
DFW
Default Re: how do i identify a y8 tranny (IVAN93EG)
Should have a sticker on it, says S20 - XXXXXXX
Old May 10, 2006 | 07:37 PM
Jim Truett's Avatar
Default Re: how do i identify a y8 tranny (DFW)
For a Y8 it should be S40 and stamped B000 by the oil fill plug. 92-95 EX/Si are S20/P20
Old May 10, 2006 | 07:39 PM
drewbie's Avatar
Default Re: how do i identify a y8 tranny (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">For a Y8 it should be S40 and stamped B000 by the oil fill plug. 92-95 EX/Si are S20/P20</TD></TR></TABLE>
the stamp on the 5th gen si/ex will say y4g or something. CX will be J8F not sure about the y8 though
Old May 10, 2006 | 07:43 PM
Jim Truett's Avatar
Default Re: how do i identify a y8 tranny (drewbie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewbie &raquo;</TD></TR><TR><TD CLASS="quote">
the stamp on the 5th gen si/ex will say y4g or something. </TD></TR></TABLE>
Y4F
Old May 10, 2006 | 07:47 PM
drewbie's Avatar
Y4F</TD></TR></TABLE>
my Si says y4G
Old May 10, 2006 | 07:58 PM
Jim Truett's Avatar
my Si says y4G</TD></TR></TABLE>
The one I have in the garage is an EX and is Y4F. Must be the difference between 5th gear ratio.
Old May 10, 2006 | 08:00 PM
drewbie's Avatar
The one I have in the garage is an EX and is Y4F. Must be the difference between 5th gear ratio.</TD></TR></TABLE>
yeah...cuz G comes aftter F.
im on a DX tranny now thoug
Old May 10, 2006 | 08:02 PM
Jim Truett's Avatar
im on a DX tranny now thoug </TD></TR></TABLE>
If you have the old Si tranny, put it's final drive into the DX. It's not the greatest, but it will accelerate better.
Old May 10, 2006 | 08:04 PM
drewbie's Avatar
no big deal though, it was only 50$$$
Old May 10, 2006 | 08:06 PM
drewbie's Avatar
If you have the old Si tranny, put it's final drive into the DX. It's not the greatest, but it will accelerate better.</TD></TR></TABLE>
i think the FD is what's shot in my Si tranny Either that or the Differential.
I broke it at the drag strip ricer launching. I was able to drive it, but it would constantly break not out of gear, but out of drive, and would grind like heck. i couldnt go more than 15 mph either......so I called my allstate free towing
Old May 10, 2006 | 08:07 PM
Jim Truett's Avatar
I broke it at the drag strip ricer launching. I was able to drive it, but it would constantly break not out of gear, but out of drive, and would grind like heck. i couldnt go more than 15 mph either......so I called my allstate free towing </TD></TR></TABLE>
If the ring/pinion are good but the diff is broke, you are good to go. You would need to put the Si ring gear on the DX diff anyway.
Old May 11, 2006 | 04:49 AM
drewbie's Avatar
If the ring/pinion are good but the diff is broke, you are good to go. You would need to put the Si ring gear on the DX diff anyway. </TD></TR></TABLE>
waht?
Old May 11, 2006 | 06:42 AM
-DC2-'s Avatar
you cannot visually identify ANY d-series trans by anything but the bearing size
look near the tranny fill plug.........
A000 = small bearing case = CX/DX/HX/VX case, bad!
B000 = large bearing case = EX/Si case, GOOD!!!!
All EX/Si SOHC trannys are big bearing style. only external difference is the casting codes........small bearing vs big bearing
Old May 11, 2006 | 06:47 AM
NJcoupe's Avatar
Your trans should have a vin plate on it, unless it was removed for some reason
Vin should have EJ8 In it.
Old May 11, 2006 | 07:01 AM
sicones's Avatar
Default Re: (dxcoupe.)
96-00 = S40
92-95 = S20
D16y8 trans = K4F/Pa4/B000
Old May 11, 2006 | 03:14 PM
IVAN93EG's Avatar
Default Re: (sicones)
thankz. i dont want to put a dx tranny on thinking its an ex. dat would suck ball. is 100$ a good price if the tranny is working fine?
Old May 11, 2006 | 03:56 PM
johnecon2001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">96-00 = S40
92-95 = S20
D16y8 trans = K4F/Pa4/B000</TD></TR></TABLE>
K4F
Eaglekper0046
11
Dec 12, 2005 10:19 PM
struppi
May 27, 2004 09:14 AM
mRek9R
Mar 10, 2004 05:24 AM
egizzle8
14
Sep 28, 2003 09:52 AM
spencedogg
Aug 10, 2003 05:59 AM
