how do i identify a y8 tranny
getting a y8 tranny this friday and im not sure how to tell if it"s an ex tranny.mine took a fat turd wednesday.
Re: how do i identify a y8 tranny (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">For a Y8 it should be S40 and stamped B000 by the oil fill plug. 92-95 EX/Si are S20/P20</TD></TR></TABLE>
the stamp on the 5th gen si/ex will say y4g or something. CX will be J8F not sure about the y8 though
Re: how do i identify a y8 tranny (drewbie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewbie »</TD></TR><TR><TD CLASS="quote">
the stamp on the 5th gen si/ex will say y4g or something. </TD></TR></TABLE>
Y4F
Y4F
Y4F</TD></TR></TABLE>
my Si says y4G
my Si says y4G
my Si says y4G</TD></TR></TABLE>
The one I have in the garage is an EX and is Y4F. Must be the difference between 5th gear ratio.
The one I have in the garage is an EX and is Y4F. Must be the difference between 5th gear ratio.</TD></TR></TABLE>
yeah...cuz G comes aftter F.
im on a DX tranny now thoug
im on a DX tranny now thoug </TD></TR></TABLE>
If you have the old Si tranny, put it's final drive into the DX. It's not the greatest, but it will accelerate better.
no big deal though, it was only 50$$$
If you have the old Si tranny, put it's final drive into the DX. It's not the greatest, but it will accelerate better.</TD></TR></TABLE>
i think the FD is what's shot in my Si tranny Either that or the Differential.
I broke it at the drag strip ricer launching. I was able to drive it, but it would constantly break not out of gear, but out of drive, and would grind like heck. i couldnt go more than 15 mph either......so I called my allstate free towing
I broke it at the drag strip ricer launching. I was able to drive it, but it would constantly break not out of gear, but out of drive, and would grind like heck. i couldnt go more than 15 mph either......so I called my allstate free towing </TD></TR></TABLE>
If the ring/pinion are good but the diff is broke, you are good to go. You would need to put the Si ring gear on the DX diff anyway.
If the ring/pinion are good but the diff is broke, you are good to go. You would need to put the Si ring gear on the DX diff anyway. </TD></TR></TABLE>
waht?
waht?
you cannot visually identify ANY d-series trans by anything but the bearing size
look near the tranny fill plug.........
A000 = small bearing case = CX/DX/HX/VX case, bad!
B000 = large bearing case = EX/Si case, GOOD!!!!
All EX/Si SOHC trannys are big bearing style. only external difference is the casting codes........small bearing vs big bearing
Re: (sicones)
thankz. i dont want to put a dx tranny on thinking its an ex. dat would suck ball. is 100$ a good price if the tranny is working fine?
Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">96-00 = S40
92-95 = S20
D16y8 trans = K4F/Pa4/B000</TD></TR></TABLE>
K4F
92-95 = S20
K4F
