compression ratio help
Old May 10, 2006 | 05:50 PM
lsvtechatch92's Avatar
Default compression ratio help
currrently building a lsvtec set up i have a b18a block with gsr head i was wondering what compression ratio i would be looking at with pr3 pistons, type r pistons, and gsr pistons... and if there is any valve to piston clearance with any of these if someone could tell me which one would give me clearance problems if any and which one should be best for the application...keep in mind i will be using nitrous no more than a 100 shot.... most likely a 50 or 75 shot until tuned.... thinks alot... i am wanting to run around 11.5:1 would like to go more but i dont think it would be safe with the nitrous.... thanks to everyone who helps
Old May 10, 2006 | 06:13 PM
HELP ME OUT GUYS
Old May 10, 2006 | 09:16 PM
b20powereDA's Avatar
Default Re: compression ratio help (lsvtechatch92)
http://www.c-speedracing.com/howto/compcalc/compcalc.php
i would look for u but to lazy so i figured u could do it on ur own
Old May 10, 2006 | 09:39 PM
Default Re: compression ratio help (b20powereDA)
thanks buddy... ive already done that but from other peoples builds ive seen alot higher compression ratios than that compression calculator gives you
lsvtechatch92
May 10, 2006 09:53 PM
boosted k20
Jul 26, 2005 07:46 PM
kelvin_24
May 29, 2004 05:11 AM
h22squeaker
Jun 12, 2003 12:04 PM
turboex
Nov 7, 2002 10:55 AM
