what should i do p28 in d15b vtec jdm?
Old May 10, 2006 | 05:11 PM
CivicHP's Avatar
Default what should i do p28 in d15b vtec jdm?
i am running a p28 ecu with a d15b jdm i am thinking of either getting my ecu reprogramed to p08 maps and timing or should i just get the p08 and convert it to o2 4 wire? if i reprogram the p28 to p08 i will have to convert it to 1 wire o2?
Old May 10, 2006 | 05:20 PM
schardbody's Avatar
no you dont, you can have p08 maps put in your p28 and keep 4wire. honestly you arent gonna notice much differance.
Old May 10, 2006 | 05:36 PM
sohcvtec1995's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">honestly you arent gonna notice much differance. </TD></TR></TABLE>
Old May 11, 2006 | 07:02 AM
CivicHP's Avatar
well it will help my gas millage and won't run rich anymore that what i want i don't care realy about more power. how much will that cost around?
Old May 11, 2006 | 07:22 AM
DJ_SaNdOz's Avatar
Default Re: (CivicHP)
I chipped my P28 w/ a P08 EEPROM. I noticed better throttle response, and a noticible increase in my MPG. I would suggest doing it.....
Old May 11, 2006 | 07:23 AM
CivicHP's Avatar
thanks how much it cost you?
Old May 11, 2006 | 07:24 AM
Relic1's Avatar
cutting out fuel when you're running rich will actually give you power.
chip the P28 with P08 maps, on a P30-203 base in Crome. Do a little minor tuning of the extended features and you'll have more power and better mpg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHP &raquo;</TD></TR><TR><TD CLASS="quote">thanks how much it cost you?</TD></TR></TABLE>
you can do it yourself if you can solder. All you'll need is a burner and the parts to do it. roughly $40 depending on what you buy for a burner and where you get the parts.
Old May 11, 2006 | 09:34 AM
CivicHP's Avatar
thanks alot for the help
Old May 11, 2006 | 10:54 AM
schardbody's Avatar
or just advance your timing at the dizzy, and dont worry about it. run 87 octane if you arent already.
westsideaznboi
13
Jul 11, 2008 05:45 PM
l1bid0
Apr 15, 2007 05:43 PM
zenon8890
Dec 9, 2006 01:37 PM
mcgee*
11
Apr 2, 2006 07:38 PM
trooper0641
Sep 13, 2004 07:37 PM
