Cylinder #1 Not Running - Got Spark/Fuel/Timing - Pull Plug Up And Its Perfect? Why?
Car is a d16a6 obd0 brand new engine with some internal work done to it
I thought it just sounded choppy at idle but when I drove it yesterday it sounded like a bike
Well just now I pulled the spark plugs one by one and 2-4 almost cause the engine to stall out and die, pulled the #1 plug and nothing happened
<FONT SIZE="20">BUT</FONT>
When I was slipping it back in I heard the engine noise grow, clicked it into place and it went back to stutterring
So I pulled it back out a bit, maybe 3/4" and the cylinder starts firing!!!
WTF
So I put in a set of known good magencore wires and it did the same thing, you cna pull it out a bit and the motor sounds mint, sounds perfect, plug it into place and the cylinder stops firing, for 2 sets of wires
WTF would cause this?
I'll post a video in a second
WTF
Very Emergency!!
did you try a new set of plugs? maybe there is some resistance in the top of the spark plug.
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS »</TD></TR><TR><TD CLASS="quote">I guess I shoulda switched that plug to a different cylinder</TD></TR></TABLE>
well, when you get a chance you can do that and see if it helps.
i had that same problem in cyl # 1... i would pull the plug out a tiny bit and the cyc would fire... my blaster coil actually went bad and for some reason when i replaced it the problem disappeared.... which makes no sence because its pre dizzy and shouldve affected all cyc... dont ask me why but it worked...
For reference, I changed all four spark plugs and gapped them properly and cleaned of my spark plug wire grommets (underside of valve cover) and the problem cleared right up ran mint
PINKS
May 10, 2006 09:28 PM
PINKS
10
May 10, 2006 05:19 PM
