Miss Fire Problem?!?! D16y8. I have searched.
Old May 10, 2006 | 03:18 AM
Xion's Avatar
Default Miss Fire Problem?!?! D16y8. I have searched.
Hey guys, I was wondering if anyone could help me out here.
My car has a miss fire that occurs usually only when it's hot and I have been driving for a while. Only happens at 1/4 throttle and idle.
No CEL. Which is weird.
I have searched through Honda-Tech for similar problems, and it seems to be ignition related, which I thought.
I have changed my plugs, wires, cap, rotor, coil and ignitor and it STILL does it. Maybe fuel related, but would I not get a lean code if that was the case?
I was just wondering if anyone has any ideas on this, maybe something I missed?
I would really appreciate it.
Thanks guys.
Old May 10, 2006 | 05:13 AM
Jorsher's Avatar
Haha I've been fighting a similar problem for months and haven't figured it out. Someone else posted about it yesterday with the same engine. I've replaced all the same crap. Mine doesn't misfire at idle though, only seems to while accelerating, i have got a CEL twice in the past year for "random misfire in cylinders 1 & 2"... if you figure it out lemme know lol. I've replace ignition coil, wires, plugs, oil/air/fuel filters, tested tps/map, checked timing, no luck
Old May 10, 2006 | 06:09 AM
axtran's Avatar
misfires can be that your exhaust is to big for your engine too, haha i had a vw in the past and 2.5" exhaust was much too much
Old May 10, 2006 | 06:33 AM
jakedoza's Avatar
Default Re: Miss Fire Problem?!?! D16y8. I have searched. (Xion)
have you tried cleaning out the plug at the dist.. i had a little oil get in mine at one time and had the same issue.. cleaned it out and presto no more problems.
Old May 10, 2006 | 01:35 PM
Xion's Avatar
Default Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">misfires can be that your exhaust is to big for your engine too, haha i had a vw in the past and 2.5" exhaust was much too much</TD></TR></TABLE>
Mines stock..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7 &raquo;</TD></TR><TR><TD CLASS="quote">have you tried cleaning out the plug at the dist.. i had a little oil get in mine at one time and had the same issue.. cleaned it out and presto no more problems.</TD></TR></TABLE>
Damn, thats a good idea, didn't even think of that.
Old May 10, 2006 | 05:03 PM
Xion's Avatar
Any other ideas?
Old May 10, 2006 | 08:30 PM
Jorsher's Avatar
heh
Old May 11, 2006 | 03:23 AM
Xion's Avatar
Default Re: (Jorsher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jorsher &raquo;</TD></TR><TR><TD CLASS="quote">Haha I've been fighting a similar problem for months and haven't figured it out. Someone else posted about it yesterday with the same engine. I've replaced all the same crap. Mine doesn't misfire at idle though, only seems to while accelerating, i have got a CEL twice in the past year for "random misfire in cylinders 1 & 2"... if you figure it out lemme know lol. I've replace ignition coil, wires, plugs, oil/air/fuel filters, tested tps/map, checked timing, no luck</TD></TR></TABLE>
Yeah and it's so annoying when you got to drive for long periods of time. Also it really sucks wasting money on expensive as hell ignitors and coils!
Old May 11, 2006 | 03:46 AM
EE_Chris's Avatar
You said the car was stock? How many miles? Have you verified the timing with a timing light? Have you set the valve lash recently/at all?
Old May 11, 2006 | 04:48 AM
Jorsher's Avatar
Default Re: Miss Fire Problem?!?! D16y8. I have searched. (EE_Chris)
So you already tried ignitor? Good, now I don't have to waste money on that like I did the ignition coil lol.
I'm going to check the valve lash this weekend, getting everything ready for boost
Old May 11, 2006 | 02:34 PM
Xion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">You said the car was stock? How many miles? Have you verified the timing with a timing light? Have you set the valve lash recently/at all?</TD></TR></TABLE>
It's got 120 000 KM on it. The timing is fine(I checked it) and so is the valve lash(done recently to spec).
Old May 11, 2006 | 02:44 PM
EJ1 wilcox's Avatar
My old car used to do this as well. I'd be sitting at a stop light and it would randomly miss and kind of shiver and then go back to normal.
It also happened a few times while accelerating at low RPM.
I never figured out why it was doing it. I had replaced the cap, rotor, plugs and wires, and it still did it.
I never got any CELs either.
Old May 12, 2006 | 02:01 AM
Xion's Avatar
Default Re: Miss Fire Problem?!?! D16y8. I have searched. (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">My old car used to do this as well. I'd be sitting at a stop light and it would randomly miss and kind of shiver and then go back to normal.
I never got any CELs either. </TD></TR></TABLE>
Yeah thats exactly what mine does, it will randomly do it than go away for awhile. Sometimes like a day than start doing it again.
Old May 12, 2006 | 02:17 AM
Syndacate's Avatar
double check that timing..
Next step I believe would be testing the fuel pressure
When was the last time the fuel filter was changed? (Check fuel pressure)
Old May 12, 2006 | 06:34 AM
EJ1 wilcox's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">double check that timing..
When was the last time the fuel filter was changed? (Check fuel pressure)</TD></TR></TABLE>
Could it be the timing? I mean, if the timing was a bit off how would it cause a random misfire to happen only every once in a while? I'm almost positive that my timing was dead on and my fuel pressure was fine. And I know the fuel filter was fine because I had replaced it just a few months before it started happening.
Old May 19, 2006 | 04:38 PM
Xion's Avatar
Wow it was my fuel filter. Changed it three days ago and it hasn't missed fired since.
It was changed a year and a half ago, so I assumed it wouldn't be that bad yet. I also didn't think, since it only happened randomly that it would be the fuel filter.
I was suprised.
Thanks for the help everyone.
Old May 19, 2006 | 05:07 PM
hott95ej2's Avatar
Default Re: (Xion)
how about checking that valve lash
Old May 19, 2006 | 05:15 PM
gezzercivic20's Avatar
i replaced the altenator on a 99 gsr and the misfire for cly 2 dissapeared.
jrock1234
May 8, 2012 08:16 AM
LST2
Jul 28, 2008 06:05 PM
arospeedintegra
May 30, 2008 01:20 AM
y0whuddupb
Feb 14, 2006 05:45 PM
8200RPM
May 11, 2004 08:01 PM
