How many rpms with built lsvtec
Old May 9, 2006 | 09:28 AM
koolaid3246's Avatar
Default How many rpms with built lsvtec
Hey ive searched the forum with no luck. Im wanting to know where to saftly stop spinning my new lsvtec turbo setup. Im looking for just over 400whp if possible any input from experince would help thanks.
Motor setup:
b16 head
holley 62mm tb
victor x manifold
gsr cams
crower springs and retainers
supertech stainless valves
81.5 je pistons
eagle h rods
gsr block with arp main,head, and rod studs
ls mircropolished and balanced crank
Turbo setup:
turbonetics t3/t4 57trim .63 ar turbo
ram horn manifold
tial 38mm wg
greddy type rs bov
cca intercooler
3 inch exhaust
Old May 9, 2006 | 09:45 AM
non-VTEC's Avatar
Default Re: How many rpms with built lsvtec (koolaid3246)
with gsr cams and that turbo you should be good to a little over 8000rpm....8500 MAX
Old May 9, 2006 | 09:53 AM
cuin9sec
Guest
Posts: n/a
you wont know for sure until you put it on the dyno and see when it stops making power. i would guess 9-9500rpms.
Old May 9, 2006 | 12:56 PM
vaporboy12's Avatar
Default Re: How many rpms with built lsvtec (cuin9sec)
l reved my ls/vtec to clost to 10,000 on eagle rods
Old May 9, 2006 | 03:06 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koolaid3246 &raquo;</TD></TR><TR><TD CLASS="quote">
eagle h rods
= what can take the revs (looks like 9,000+ RPM)
b16 head
holley 62mm tb
victor x manifold
gsr cams
=Decides where the power will be ESPECIALLY the cams. Those cams on boost should start dropping torque around 8,400-9,000 RPM. This is variable because of many many many factors like amount of boost, manifold, TB, etc, etc, etc....every setup is different.
Old May 9, 2006 | 03:08 PM
Chip's Avatar
Default Re: How many rpms with built lsvtec (adseguy)
Reving out to 9K will probably give you the meatiest powerband. I turned my eagle rodded LS/VTEC to 9500 all day without issue.
Old May 9, 2006 | 04:09 PM
komat's Avatar
Default Re: How many rpms with built lsvtec (Chip)
i will be reving my lsvtec with supertech valve tran to 9500rpm
Old May 9, 2006 | 04:50 PM
TurboR1391's Avatar
I rev mine to 9k. Revlimiter is 9100. I am going to change from GSR to CTR cams next month. Will see how the power picks up past 8k.
Old May 9, 2006 | 05:20 PM
drumking15's Avatar
wow pretty much the same setup as myself...although ive only been running it out to 8200....maybe ill give it a lil more breathin room once i strap it on the rollers and see what it makes
Old May 9, 2006 | 05:42 PM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">= what can take the revs (looks like 9,000+ RPM)
=Decides where the power will be ESPECIALLY the cams. Those cams on boost should start dropping torque around 8,400-9,000 RPM. This is variable because of many many many factors like amount of boost, manifold, TB, etc, etc, etc....every setup is different.</TD></TR></TABLE>
the gsr cams torque shouldnt start dropping at all at the power range he is looking for. he should be just perfect.
jdmb16turbo
May 13, 2009 07:00 PM
PIMPROB
Nov 27, 2006 01:24 PM
Garage 808 Hatch
Sep 9, 2006 11:02 PM
Samuels
Aug 11, 2006 06:39 PM
ExplicitSpeed
Mar 8, 2004 10:59 PM
