Collector how to....
Old May 9, 2006 | 12:33 AM
hondaapi's Avatar
Default Collector how to....
At first I used the search!
In the past I made my needed collectors with a hand grinder (hope it is the right english word).
But now I need a lot of collectors. I know that some people build them with a band saw and something that holds the material in position while cutting.
Do you guys havesome pics of how such a thing looks like?
I´m thankful for every suggestion.
Old May 10, 2006 | 09:21 AM
JDMs1eeper's Avatar
Default Re: Collector how to.... (hondaapi)
Collectors are a huge PITA and until you get it down pat, practice on some PVC.
just'a hint for starters
Old May 11, 2006 | 12:24 AM
hondaapi's Avatar
Default Re: Collector how to.... (JDMs1eeper)
You misunderstood me. I made a lot of collectors in the past. Unfortunatly I just fabricated them with a hand cutter and hand grinder. Believe me, they came out in very good quality. But it takes me 1.5-2hours to build each colector. That sucks.
Now I need a lot of collectors and so I´m searching for a way to build them with a machine to save me time and work.
Do you understand what I want to say?
So it would be great if somebody can give me some ideas or hints.
Thanks
Old May 11, 2006 | 05:10 AM
Formula Racing's Avatar
If you searched you would have seen that anyone who knows how, wont tell you!
Trial and error.. Learn on your own! This isnt something people talk about
Old May 11, 2006 | 05:11 AM
Moto-C's Avatar
B A N N E D
there was a thread over on fab-forum.com with a couple different collector jig designs but the pics no longer show up. search over there just search for collector and itll pop up
Old May 11, 2006 | 06:44 AM
wade's Avatar
Default Re: (Moto-C)
use pvc at the same time use them on the trial and error JIG you need to make, once the jig cuts the PVC as you need, then weld the jib up, use SS and you are done
Old May 24, 2006 | 06:50 AM
Z10ROB's Avatar
We have these in stock, they are stainless steel. Alot of work and research went into developing these.
Thanks,
Rob
Old May 24, 2006 | 07:02 AM
franktype-r's Avatar
Default Re: Collector how to.... (Z10ROB)
Very nice, how much and how many can I buy.....
Old May 24, 2006 | 07:52 AM
fabnewb's Avatar
Default Re: Collector how to.... (franktype-r)
wow very impressive please im the details on your collecter z10.
Old May 24, 2006 | 08:31 AM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by franktype-r &raquo;</TD></TR><TR><TD CLASS="quote">Very nice, how much and how many can I buy..... </TD></TR></TABLE>
Yeah, esp since your website is very lacking, and doesn't show them. They look **** though
Old May 24, 2006 | 08:49 AM
Justin Olson's Avatar
Default Re: Collector how to.... (HiProfile)
What size outlet does the z10 collector have? Looks like a nice piece. Just curious if it matches the ID of a t3 or t4 turbine side?
Regards,
Justin
Old May 24, 2006 | 01:20 PM
all_motor_mike's Avatar
Default Re: Collector how to.... (Justin Olson)
that is ******* sick!
Old May 24, 2006 | 04:23 PM
Moto-C's Avatar
B A N N E D
they have them for both t3 as well as t4. spoke with Ron this morning. great pieces.
Old May 24, 2006 | 05:12 PM
shortyz21's Avatar
how much does it weigh
Old May 24, 2006 | 06:24 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (shortyz21)
nice finish on the casting.
just curious, how much does it weigh?
Old May 24, 2006 | 07:35 PM
again i say, how much, and how many can i buy
Old May 24, 2006 | 07:53 PM
ChainbreakR's Avatar
Jumping aboard...prices And what the recess in the tops are for as far as tube size is concerned...
Old May 24, 2006 | 09:14 PM
90TegraB18C's Avatar
Default Re: Collector how to.... (ChainbreakR)
Very nice piece there...
Pricing would be great if possible... also... how come they are not drilled / threaded? Or is that the unfinished piece?
As Ken Peak asked... how much does it weigh and what kind of coating is it?
Thanks
Old May 25, 2006 | 03:59 AM
Z10ROB's Avatar
Default Re: Collector how to.... (fabnewb)
The collectors are 150 each with quan discount available the collector has a t3/t4 flange and comes drilled. They are set up for 1.5 inch ID pipe or tube. The relief in the top fits 1.5 sced 40 pipe fittings. The finish is as cast. The weight is 4.7 pounds, it equivalent to a schd 40 collector. The wall thickness is for fatigue resistance.
Old May 25, 2006 | 06:49 AM
JDMCRX's Avatar
Man im gonna be ordering a few of those soon
Old May 25, 2006 | 08:56 PM
c jackson's Avatar
threes
Default Re: Collector how to.... (JDMCRX)
has anyone ever tried to weld a sch 40 pipe to that yet?
Old May 25, 2006 | 08:59 PM
B18C1CYA's Avatar
Default Re: Collector how to.... (c jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ever tried to weld a sch 40 pipe to that yet?</TD></TR></TABLE>
I would like to see that also , maybe even a mocked up or finished manifold with one
Old May 25, 2006 | 11:09 PM
*Boostwerks*'s Avatar
Hoe damn. I gotta get me some of those.
Old May 26, 2006 | 04:21 AM
Synapse Motorsport's Avatar
Default Re: (Bryson)
Very nice
Old May 26, 2006 | 08:05 AM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaapi &raquo;</TD></TR><TR><TD CLASS="quote">At first I used the search!
I´m thankful for every suggestion.</TD></TR></TABLE>
Search ? You didnt search nuttin...
https://honda-tech.com/zerothread?id=1440844
