Gains from increasing CR by 1.9 points...?
Old Apr 10, 2002 | 01:58 PM
B19CivicHB's Avatar
Default Gains from increasing CR by 1.9 points...?
This is in my 95 JDM GSR engine and Ill be using the stock head. CR will go from 10.6- 12.5. Also the usual i, h, e, JUN flywheel. Id dyno it but it isnt in the car yet... Anyway I was just wondering if with that setup it'd put me and my hatch consistantly in the 13's. Im a decent driver so no worries there. Thanks for any input.
-Nick-
Old Apr 10, 2002 | 06:37 PM
B19CivicHB's Avatar
Default Re: Gains from increasing CR by 1.9 points...? (B18CivicHB)
no one?
Old Apr 10, 2002 | 06:46 PM
fowler!'s Avatar
What pistons are you putting in? CTRs? They would probably give you a few horsepower. Most likely 10-15 at the most.
Make sure you can get some good gas where you're at. 12.5 is pretty high
Old Apr 10, 2002 | 06:50 PM
B19CivicHB's Avatar
Default Re: Gains from increasing CR by 1.9 points...? (fowler)
They are JE 12.5:1 pistons. I use 94 octane pump gas and im retarding ignition timing 3 degrees. Soon ill get a VAFC and a FPR and have it all tuned.
Old Apr 10, 2002 | 07:54 PM
HXMan's Avatar
Seems like the increased compression won't be fully realized until you have some good cams to go along with it.
Old Apr 10, 2002 | 08:27 PM
tonydatyga's Avatar
Default Re: Gains from increasing CR by 1.9 points...? (HXMan)
that's sounds good
Old Apr 11, 2002 | 05:26 AM
B19CivicHB's Avatar
I plan on building the head this winter once i get some more cash. Dont have enough right now to do both.
Old Apr 11, 2002 | 12:13 PM
93LSVTEC's Avatar
I think the general rule, not taking outside cirumstances into play (like agressive cams) , is around 5 HP per a point. But, the higher the compression the more you can "take-advantage" (the best way to put it) of tuning and extra mods. So you might see 10hp if that is all you do, but once you start adding mods that # will incease substanially.
Suck my DX
10
Dec 28, 2006 06:30 PM
JBONES
Jan 15, 2003 09:17 AM
B19CivicHB
Mar 22, 2002 08:51 AM
2fastGSR
Nov 11, 2001 12:30 PM
Toda Party
Aug 20, 2001 11:39 AM
