what the? heat shield bolts
Old May 8, 2006 | 05:34 PM
excivicboy96's Avatar
Default what the? heat shield bolts
any suggestions on how to get some stuck bolts off my heatshield? tried everything.
Old May 8, 2006 | 05:35 PM
Archidictus's Avatar
Unceasing Measure
Default Re: what the? heat shield bolts (excivicboy96)
A.) which heat shield
B.) list for me what you've tried: I'll bet I can give you two good answers that you haven't tried yet
Old May 8, 2006 | 05:37 PM
Default Re: what the? heat shield bolts (Archidictus)
that damn heatshield over the exhaust manifold. there rusted right on. tried wd-40 and brushing the rust off. out of ideas.
Old May 8, 2006 | 05:42 PM
jtchinoy's Avatar
my heatshield on my header was so rusted the washer welded to the heat shield snapped before it would budge. In the end I used a bolt cutter to take my head shield off. If your washer snaps, time to get a bolt cutter.
Old May 8, 2006 | 05:44 PM
Default Re: (jtchinoy)
is there another option?
Old May 8, 2006 | 05:47 PM
eg six's Avatar
you could heat it up with a torch until it gets red hot then try loosing them
Old May 8, 2006 | 05:49 PM
jtchinoy's Avatar
Default Re: (excivicboy96)
Try holding the washer with a vice grip and use leverage on the bolt? Tried that for a bit, didn't go well (did it after the washer came off). Might work for you if you have a friend hold the vice grip while you rotate AND the washer hasn't snapped off the weld yet. Not a great way IMO, you chance having the force send your friend's hand into part of the engine to mess his hand up. Other than that, no clue.
Old May 8, 2006 | 06:56 PM
CRXified's Avatar
drive the car around until its hot (operating temp) and them take a torch to the bolts to see if it helps. just dont burn urself
tpot90
Apr 5, 2008 09:46 AM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
4DRmafia
15
Oct 27, 2004 04:51 PM
BrokeAssAcura
Jun 5, 2003 12:59 PM
syndicate43
Nov 25, 2002 05:49 PM
