VTEC solenoids
B and D are swapable, but i dont recommend it. My friend tried it once on his D15B. He put on a B16 solenoid and it kept throwing a check engine light and wouldnt let him rev out all the way.
If you keep you engine full of fresh oil then you can try cutting the screen out on the stock solenoid. Maybe even drill out a hole or two to increase flow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sandmaggot »</TD></TR><TR><TD CLASS="quote">If you keep you engine full of fresh oil then you can try cutting the screen out on the stock solenoid. Maybe even drill out a hole or two to increase flow.</TD></TR></TABLE>
What purpose does this serve and why are you recommending this to someone?
1ntensiveVTECivic
15
Nov 15, 2003 09:53 PM
