Help my B18C outputs only 100bhp!!!!!
Old May 8, 2006 | 02:18 PM
khmoe's Avatar
Default Help my B18C outputs only 100bhp!!!!!
Hello, i have a big problem, because my motor startet 2 month ago to only output 100hp.
The car works fine when i drive it around the city, but i can sense that it does not have the power it used to have . But when i take it on the freeway and go Vtec it does not accelerate any good, it almost stops before going further/higher in rpm. It is not jerking it is only stopping/slowing down the acceleration.
If i hold the throttle down i neuteral it shoots in the exhaust.
There is no cel code.
Some times it starts to jerke when i'm crusing at 2000rpm
What i have tried to do to fix the problem:
New Dizzy
New Map sensor
new oil and oil filter
new fule filter
new spark plugs
Checked the Cat.
Help me, I need help, have to get the car running for the Track days
Best Regards
Kristian Henriksen Moe
Norway
Honda Civic 1995(EG) w/B18C (OBD2a) and ITR brakes.
BTW: Sorry for my bad english
Modified by khmoe at 9:52 AM 5/9/2006
Modified by khmoe at 1:51 PM 5/15/2006
Old May 8, 2006 | 02:21 PM
khmoe's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (neo_)
Norway
Old May 8, 2006 | 02:29 PM
khmoe's Avatar
How can i check the injectors???
Old May 8, 2006 | 05:43 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression and leakdown test.
spark plugs?
Have you missshifted lately? Over-reved? Sucked up any water?
Old May 9, 2006 | 12:51 AM
khmoe's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (Dr Pooface)
Have changed the sparkplus to.
Ihave not over reved, and i do not think i have gotten any water into the motor.
Old May 9, 2006 | 05:12 AM
b19coupe's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (khmoe)
Does the car have a catalytic converter? A clogged cat can cause similar symptoms.
Old May 9, 2006 | 05:20 AM
Circuit Star-29's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (b19coupe)
Why are you still running OBD2? If none of the stuff already mentioned doesn't cure anything, you may want to check bearings...
for a month I was driving around on a spun bearing...well, it was working its way out anyway,...I starved the motor a few times of oil (DOH!!!) and then one day missed a shift and the engine shot upto about 11k...... Nothing bent but the bearing couldn't take ti anylonger...engine blew...
After the first episode of the oil starvation, the motor lost about 15-30 hp...butt dyno tells me so... Just something you should look into if nothing else helps. And go OBD1...I dun understand why you're obd2...
Side note...New engine goes into today...Ill post pix.
Old May 9, 2006 | 10:37 AM
khmoe's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (Circuit Star-29)
hvat bearings? The engine has 46000 km on it.
I'm running OBD2a because my car was obd0, All europen honda civic 1,5LSi(DPFI) is OBD0 or pre-obd.
If it is the cat, i should see if it's clogged???
Thanx for the input!
Old May 11, 2006 | 02:01 PM
khmoe's Avatar
Any more ideas??????????
I need help, Going to look into the Cat and see if something is wrong there tomorrow.
I'm clueless right now
I whant to race again, there are som 200sx that needs a beating
Old May 11, 2006 | 02:37 PM
emotionisdead's Avatar
Very Emergency!!
it sounds like a clogged cat to me. one of my old roomates had a clogged caat and it wouldn't even rev pass 3000 in neutral.
Old May 15, 2006 | 04:50 AM
khmoe's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (emotionisdead)
It's not the Cat. , i can see light in the other end, just as when i put it on the car the first time, so it is not the cat.
What can it be??
The cars idle is at 1050rpm, but it has always been that high. But recently the idle has gone down to 800rpm and then back up to 1050rpm, could it be that a sensor the is ajusting the idle speed is making the power loss at high rpm??
Thanx for any reply.
Old May 15, 2006 | 07:28 PM
QQ's Avatar
QQ
check your TPS & main O2 sensor, coz if the O2 have problem the engine light not light up some time. Also try unplug the TPS and see the engine run ok or not. When you unplug the TPS the engine light on and idle around 1500 rpm. Let try that 2 things.
Old May 16, 2006 | 09:39 AM
ericlee303's Avatar
Did you check the timing??
Old May 16, 2006 | 09:57 AM
Yellow Dragon's Avatar
Default Re: (ericlee303)
Updates?
Old May 16, 2006 | 10:16 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Yellow Dragon)
Are the plug wires in the right firing order?
Old May 16, 2006 | 10:53 AM
MilFhunter001's Avatar
I just got my car dynod and the first run it only freakin pulled a 128.9 hp and forgot the tq.
The second run after tuning pulled 149.3 @ 107 tq
Third was 152 at 109 Tq.
It was tuned on Crome
The head was port and polished with three angle valve job. Stock bumpsticks (i think this could be the problem). Arias pistons CTR profile. Stock rods.
AEM FPR, Vortech fuel rail, stock injectors, stock fuel pump.
Spoon 421 header, test pipe, stock exhaust.
I need to do a compression test on it when i get it back from the tuner.
Any other suggestions would be great.
Modified by hondabitch at 10:53 PM 5/16/2006
Old May 16, 2006 | 08:16 PM
gsr dood's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (hondabitch)
check ur clutch? may not be grabbin 100% anymore
Old May 16, 2006 | 09:56 PM
Default Re: Help my B18C outputs only 100bhp!!!!! (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">check ur clutch? may not be grabbin 100% anymore</TD></TR></TABLE>
It's a fairly new clutch. I i'm going to do a running compression test on it and check the valves tomorrow.
Old May 17, 2006 | 04:48 PM
$ISELLTOU4LESS$'s Avatar
i Have a B16a, and it has kind of the similar problem. I think it is my VTEC SOlenoid. try and change ur VTEC Solenoid.
khmoe's Avatar
does the ecu read data from o2 sensor under full trottle??
Can i use TPS from a civic or do i need the itr TPS???
Because when i disconnect the TPS the ideling is stil 1050rpm.
Old May 18, 2006 | 01:19 PM
khmoe's Avatar
Bump.
Will a TPS from a civic work on the ITR trottle body??
Old May 18, 2006 | 01:26 PM
cool guy name
yes
Old May 19, 2006 | 08:21 AM
khmoe's Avatar
Default Re: Help my B18C outputs only 100bhp!!!!! (walker111)
Thanx.
So any D-series will work, Going to the salvage on monday. thay have an ESI there
Old May 21, 2006 | 08:10 AM
khmoe's Avatar
I took the TPS of the trottlebody today and mesured it whit an Ohm meter.
I got a strait kurv from 0.3k ohm to 5.0k ohm, and 5.3k ohm to 0.4k hom on the other side. is this about right?
If this seams ok, that i think it is, what the hell is wrong with my car
Gone start crying soon
Old May 21, 2006 | 09:30 AM
SLVRSTN_DC4's Avatar
i have the same problem as you do, i change my cat, spark plugs, injectors and etc... you can think of. After diagnosing this crap for like 3 months now, the only thing i can think of happening is possibly the ecu itself. My suggestion is to borrow someone elses ecu and plug it in and take a test drive. If that solves your issue, you are all set, thats what Im trying next.
Good luck
fyjimo_jr
Feb 4, 2015 10:33 AM
speedfreak44
Jun 6, 2014 02:34 PM
MainStreamHonda
43
Sep 7, 2009 04:05 PM
khmoe
Jun 11, 2006 02:17 PM
apexinghonda
Oct 24, 2004 12:14 PM
