Rear disc convertion on a hatchback>?
Old May 7, 2006 | 05:31 PM
b20vtec-hatch's Avatar
Default Rear disc convertion on a hatchback>?
I was gona put rear discs on my hatch its a 96 and i was wondering if I need to put a new master cylinder and P.V on it> or if it would be fine with my stock civic one ?
Old May 7, 2006 | 06:13 PM
Jmunk's Avatar
You can use the ones on your car, but you would benefit from a bigger MC.
Old May 7, 2006 | 06:34 PM
axtran's Avatar
i have stock MC and GSR all around, works fine, i'm upgrading MC because the bigger the better!
Old May 8, 2006 | 11:25 AM
Default Re: (axtran)
thanks guys
just what i was hoping
Old May 8, 2006 | 01:28 PM
johnecon2001's Avatar
Default Re: (b20vtec-hatch)
Do you have a DX or CX? if you have the DX you'll need a new proportioning valve that splits the brake juice 40/40. The CX has that valve already in.
Old May 8, 2006 | 02:30 PM
pdiggitydogg's Avatar
hatchbacks and the em1 si ALL have the same prop valve
and gsr brakes arent special
Old May 8, 2006 | 02:49 PM
3.point.2's Avatar
keep the stock MC but upgrade to a 40/40 prop valve
Old May 8, 2006 | 05:55 PM
Default Re: (h23eg)
so should i hjust get a 99-00 civic SI p.v then? and leave the tock civic m.c
Old May 8, 2006 | 05:59 PM
EJ8 Kenobi's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">and gsr brakes arent special</TD></TR></TABLE>
more special than civic drum brakes..
Old May 8, 2006 | 08:47 PM
yes yes...but every bit of braking on the gsr is the same as the ls/gs
Old May 9, 2006 | 10:07 AM
but still smokes 96 rear drum brakes..... ls gsr anything rear disc although puting on type r suspension
whitechihatch
Suspension & Brakes
Mar 31, 2014 01:29 PM
COLKEOWN
Sep 6, 2007 10:44 AM
StolenTeg
Oct 2, 2006 01:05 PM
blackccoupe
13
Aug 29, 2005 06:11 PM
sicegcivic
12
Apr 2, 2004 04:03 PM
