Changing Brake Pads - Quick Questions
I have a couple of quick questions about the caliper bolt - you know, the one that you have to remove at the bottom of the caliper and loosen at the top of the caliper, when changing pads. Is it a 12 mm or a 14 mm? Also, is it the same for the front as the rear?
I've changed the pads on my ITR before, and I know the bolt on the GS-R is a 12 mm and on the NSX is a 14 mm, but forgot which one the ITR is. (And it doesn't say in the service manual.) TIA...
The caliper bolts are 14mm. The caliper bracket bolts are 17mm.
On the rear if I remember correctly they are 12mm and 14mm respectively.
I like these little quizzes Ken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">
Hell, I'm just surprised nobody told him to search.
</TD></TR></TABLE>Hell, I'm just surprised nobody told him to search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS »</TD></TR><TR><TD CLASS="quote">The caliper bolts are 14mm. The caliper bracket bolts are 17mm. </TD></TR></TABLE>
Yes, you would need a 14 mm wrench to change pads, and a 17 mm to change rotors and pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
Word
Shouldnt you know this answer?
</TD></TR></TABLE>Word
Thanks, guys. (And Chris, it seems I would need both 14 mm and 12 mm sockets, depending on whether I'm changing the front pads or the rear pads.)
And yes, I did try searching, didn't find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote"> (And Chris, it seems I would need both 14 mm and 12 mm sockets, depending on whether I'm changing the front pads or the rear pads.)</TD></TR></TABLE>
Good point
I haven't changed the rears nearly as often as the fronts. (duh).
Good point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli »</TD></TR><TR><TD CLASS="quote">The caliper bolts are 17mm</TD></TR></TABLE>
No one agrees with you
summary: fronts are 14mm and rears are 12mm, and bracket is 17mm.
chris - who does not like enjoy twisting in the rear caliper after replacing pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">umm... are you too lazy to bring an extra socket or wrench with you when you work on your car or something?</TD></TR></TABLE>
I usually bring a set, and sometimes bring an extra of the size for the caliper bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">I usually bring a set, and sometimes bring an extra of the size for the caliper bolt.</TD></TR></TABLE>
.. to the track.
I'm sure that was implied somewhere, but I'm pretty sure Takumi didn't catch it.
(Chris, who's avatar is named Takumi, and thinks that's a little funny)
.. to the track.
https://honda-tech.com/zerothread?id=157429
https://honda-tech.com/zerothread?id=157444
0Wn3d!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">.. to the track.</TD></TR></TABLE>
Yup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">I'm sure that was implied somewhere, but I'm pretty sure Takumi didn't catch it.
(Chris, who's avatar is named Takumi, and thinks that's a little funny)</TD></TR></TABLE>
Funny you should post that today, since I took Cosmo with me to Gingerman yesterday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=157429
Yup.
Yup.
</TD></TR></TABLE>Yup.
erikiksaz1
Nov 17, 2005 03:04 PM
