Please help me....
Old Apr 10, 2002 | 08:49 AM
civicboisi's Avatar
Default Please help me....
Sup all
I just put a D16 motor in my DX hatch. Problem is it wont go past 4500 rpm on all gears. Si's are supposed to redline around 7000 rpm. I get codes 7 and 10 which are the intake air temp and the throttle position sensor. Could it be that i have to replace both gaskets? Could that make the car run shiety?! Please help!
Old Apr 10, 2002 | 09:05 AM
rainforest's Avatar
Default Re: Please help me.... (civicboisi)
tps yea. ta yes
your in limp mode you wont be able to go over 4500 untill you fix the codes.
Old Apr 10, 2002 | 09:17 AM
civicboisi's Avatar
Default Re: Please help me.... (rainforest)
so you think it is the intake manifold gasket and tb gasket too?
in replacing this you think my car will be able to accelarate properly?
Old Apr 10, 2002 | 10:01 AM
AzG35's Avatar
How does the car idle? If it idles alright, I wouldn't worry about the gaskets. I would check your TPS voltage at closed throttle and WOT. Is your intake air temp sensor hooked up?
Old Apr 11, 2002 | 08:00 AM
civicboisi's Avatar
Default Re: Please help me.... (AzSi22)
the car idles fine. Where is the intake air temp sensor located? Im pretty sure that plug is in too. How do i check the tps voltage???
[Modified by civicboisi, 5:01 PM 4/11/2002]
Old Apr 11, 2002 | 08:02 AM
civicboisi's Avatar
just replaced intake manifold gasket...still the same shiets happends.
Old Apr 11, 2002 | 08:22 AM
Spade's Avatar
Pick up a manual for your engine at Pep Boys or something for 25 dollars.
It will tell you all you need to know on how to trouble shoot the problems.
My guess, your going to have to replace the TPS.
24rex
Aug 22, 2007 08:10 PM
Hawkze_2.3
Feb 9, 2007 07:15 PM
vultron
Dec 13, 2003 09:45 PM
civicboisi
Apr 11, 2002 07:57 AM
rockwilda
Feb 23, 2002 09:43 AM
