ls-vtec----cr vtec...
Old May 6, 2006 | 03:42 PM
tial-eg's Avatar
Default ls-vtec----cr vtec...
ok... i have a ls in my hb... i just bough a gsr head... compleat and taped for lsvtec... no can i pit a crv crank in my ls to make cr bvtec.... and what one is faster.
Old May 6, 2006 | 03:50 PM
tsdenny's Avatar
Default Re: ls-vtec----cr vtec... (tial-eg)
i believed that a crvtec requires a b20 block from a crv
Old May 6, 2006 | 04:24 PM
tial-eg's Avatar
Default Re: ls-vtec----cr vtec... (void_accord)
c i heard... that the crv... b20 crank will fit and change your stroke so it makes it 2.0L... just like a b17 crank will fit in to a b18.. or b16...
Old May 6, 2006 | 06:12 PM
UberJDMef8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by void_accord &raquo;</TD></TR><TR><TD CLASS="quote">i believed that a crvtec requires a b20 block from a crv</TD></TR></TABLE>
Old May 6, 2006 | 07:04 PM
UNKNOWN_MEMBER's Avatar
ls and b20 cranks are the same stroke. 89mm. only difference between the blocks is that the b20 has a bigger hole (84mm) compared to ls (81mm) that is why b20 is a 2liter.
Old May 6, 2006 | 08:18 PM
nipcup101's Avatar
my opinion just stick with the ls bottom end its way stronger and cheap to get another one if u ever do something stupid on it lol
Old May 6, 2006 | 08:36 PM
Ruben19's Avatar
Default Re: ls-vtec----cr vtec... (UNKNOWN_MEMBER)
true!
if you want to make your ls to 2.0l. you have to sleeve your block to 84mm.
everything else is the same
Old May 6, 2006 | 11:47 PM
tial-eg's Avatar
Default Re: ls-vtec----cr vtec... (Ruben19)
cool... thx... so will i get any better peformance out of a 2.0l ls-vtec... does ant one know what ls vtec runs for hp to the wheels
Old May 7, 2006 | 04:36 AM
jdm_bones's Avatar
Depends, I have a all motor LSV bored out to 1.9 with P73 pistons, running 12.5 : 1 compression and single layer head gasket. Crank balanced and edged, egale rods, arp bolt and BLOX stage 2 valve train setup, on indivisual throttle bodies and a s300 hondata. It's a beast, she pushes 251 at wheel, and 208 lbs of torque. Haven't ran it yet, I am waiting on a JDM ITR tranny....I guess what I am trying to say is, you get what you pay for...And the reserch botton, is your only friend!
Best of luck in your new project!
Old May 7, 2006 | 04:40 AM
bks84's Avatar
Loved
Default Re: ls-vtec----cr vtec... (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">Depends, I have a all motor LSV bored out to 1.9 with P73 pistons, running 12.5 : 1 compression and single layer head gasket. Crank balanced and edged, egale rods, arp bolt and BLOX stage 2 valve train setup, on indivisual throttle bodies and a s300 hondata. It's a beast, she pushes 251 at wheel, and 208 lbs of torque. Haven't ran it yet, I am waiting on a JDM ITR tranny....I guess what I am trying to say is, you get what you pay for...And the reserch botton, is your only friend!
Best of luck in your new project!</TD></TR></TABLE>
oem p72... on eagle rods... w/12.5:1 CR.... 1.9 w/stock crank... whats the bore?
anywho, back on topic.
im in the reverse situation. ive got a b16 head [not installed] and b20b in my car now ... i cant decide if i want to build the b20, or pick up this LS real cheap....
probably end up going LSvtec.
Old May 7, 2006 | 06:07 AM
SuperSlow's Avatar
Default Re: ls-vtec----cr vtec... (4sd4dr)
if you are not sleeving/rebuilding the b20 on your build, it may be better to go ls.
Old May 7, 2006 | 04:02 PM
tial-eg's Avatar
Default Re: ls-vtec----cr vtec... (SuperSlow)
a am going to rebuild eather the ls or b20... what one will give me a over all faster and stronger running car... o ya i plan to dino tune and run to 8.5krpm... any other toughts
thegeezerkid
Jun 8, 2009 01:33 PM
wrestler72
Sep 5, 2007 08:24 AM
EK FLY
Apr 23, 2007 08:20 PM
doodooheadfart
Jul 20, 2006 05:20 PM
LsPower
Jan 17, 2003 11:01 AM
