Broke timing belt while driving.
Old May 5, 2006 | 04:44 PM
djtony5's Avatar
Default Broke timing belt while driving.
I was driving in the car and all of sudden the car cut off. Pull over and try to start it back up but it wouldn't start no matter what. Try to crank it a couple of time, but it still would not start. Tow the car back home and saw that the timing belt was broken. I was wondering if the head might have some bent valve? The car was barely at around 3,000 rpm and I did not hear any knocking noise when it happen.
Old May 5, 2006 | 05:04 PM
Wayne_Curr's Avatar
Default Re: Broke timing belt while driving. (djtony5)
Ya, you most likely have some damage. Replace the belt and see if it runs, if not you're going to need some headwork most likely =/
Old May 5, 2006 | 05:11 PM
PirateTypeArgh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">I was driving in the car and all of sudden the car cut off. Pull over and try to start it back up but it wouldn't start no matter what. Try to crank it a couple of time, but it still would not start. Tow the car back home and saw that the timing belt was broken. I was wondering if the head might have some bent valve? The car was barely at around 3,000 rpm and I did not hear any knocking noise when it happen.</TD></TR></TABLE>
time to rebuild the bottom end
Old May 5, 2006 | 05:14 PM
cm zak's Avatar
youll have to fix it before youll hear any noises...i doubt the engine would be on long enough for you to hear anything right now.
Old May 5, 2006 | 05:26 PM
djtony5's Avatar
rebuilt the bottom end? Are you serious bro? Well I guess I shall put on the new timing belt and see what happen then.
Old May 5, 2006 | 05:27 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Broke timing belt while driving. (PirateTypeArgh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateTypeArgh &raquo;</TD></TR><TR><TD CLASS="quote">
time to rebuild the bottom end </TD></TR></TABLE>
If anything, he has bent valves. Throw on a timing belt, adjust the valves, and perform a compression test.
Old May 5, 2006 | 05:30 PM
97CGPintegra's Avatar
that sucks. how many miles were on the belt?
Old May 5, 2006 | 05:32 PM
Default Re: Broke timing belt while driving. (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">???
If anything, he has bent valves. Throw on a timing belt, adjust the valves, and perform a compression test.</TD></TR></TABLE>
yeah.. most likely he bent valves.. but yeah.. get that to a shop and checked out
Old May 5, 2006 | 05:42 PM
Kyoto now's Avatar
Hondas run what's called an "interference engine application". Simply, what this means is that the pistons and valves will collide if the timing is thrown off, like in the event of a broken timing belt while the vehicle is running, regardless of RPM. Your best bet would be to pull the cylinder head and inspect the valves from underneath. It would be ashamed to go through all the trouble to put the timing belt on just to have the motor go to crap. Good luck.
Old May 5, 2006 | 05:50 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (DA9 Purist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Purist &raquo;</TD></TR><TR><TD CLASS="quote">Hondas run what's called an "interference engine application". Simply, what this means is that the pistons and valves will collide if the timing is thrown off, like in the event of a broken timing belt while the vehicle is running, regardless of RPM. Your best bet would be to pull the cylinder head and inspect the valves from underneath. It would be ashamed to go through all the trouble to put the timing belt on just to have the motor go to crap. Good luck.</TD></TR></TABLE>
You can perform a leakdown with the cams pulled. Bent valves would immediately be obvious. It would be a shame to pull a perfect cylinder head and have to pay for the gaskets. Even with an interference engine, you can get lucky depending on where the cams are located at the breaking point.
Old May 5, 2006 | 06:52 PM
93_teg_CT's Avatar
Default Re: (Dogginator)
I was driving around doing like 45, my car got quiet, I was like wtf? Timing belt broke. Dude at the garage said 99.9% chance with these engines it'll have bent valves. They put a new belt on and everything was mint. I guess I was that .1%.
Old May 5, 2006 | 07:05 PM
LSteg460's Avatar
i have done the same thing and it did not damage at al lwhat so ever to my car but it is veeeeeeerrrrry rare. i also went ahead and replaced the water pump at the same time. its a good idea in the long shot if you have the extra dollars.
Old May 5, 2006 | 09:52 PM
Kyoto now's Avatar
Default Re: (93_teg_CT)
That's true, good lookin!
ddn1313
Aug 4, 2018 02:46 PM
[713]
May 14, 2012 03:23 PM
coreyhayman
Dec 30, 2006 05:45 PM
s8an
Aug 6, 2004 11:16 PM
rokestah
Feb 3, 2003 04:20 PM
