best cam to put it stock 94 civic hatch.
Old May 5, 2006 | 08:59 AM
1jdmdude8's Avatar
Default best cam to put it stock 94 civic hatch.
what is the best cam to use in the stock 1.5L sohc civic hatch. i am auto crossing my car, and i feel it lacks power, and i want to upgrade the cam. Not sure what to look for or go with.
Old May 5, 2006 | 09:01 AM
Archidictus's Avatar
Unceasing Measure
Default Re: best cam to put it stock 94 civic hatch. (1jdmdude8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmdude8 &raquo;</TD></TR><TR><TD CLASS="quote">what is the best cam to use in the stock 1.5L sohc civic hatch. i am auto crossing my car, and i feel it lacks power, and i want to upgrade the cam. Not sure what to look for or go with.</TD></TR></TABLE>
You can put a D16Z6 engine and transmission in your car and remain in the same class (EP) if I remember correctly. Putting a cam in your engine will bump you into modified, gain you maybe 2hp and make you the laughing stock of the M3's and Porsches that play there.
Don't put a cam in your 1.5L engine. It's just not worth it.
Old May 5, 2006 | 09:06 AM
1jdmdude8's Avatar
Default Re: best cam to put it stock 94 civic hatch. (Archidictus)
i am allready in sm class. and i am actually beating a lot of the sti's and 240's and some other things, it is just the in the straights and coming out of corners it lacks the torque and pull that i need
Old May 5, 2006 | 09:07 AM
EH339's Avatar
If you don't do a whole z6 swap, at least swap the tranny. The Si gearing is more agressive than what you currently have.
Old May 5, 2006 | 09:09 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmdude8 &raquo;</TD></TR><TR><TD CLASS="quote">i am allready in sm class. and i am actually beating a lot of the sti's and 240's and some other things, it is just the in the straights and coming out of corners it lacks the torque and pull that i need</TD></TR></TABLE>
In that case, Gude makes a good one . Seriously though, it's not going to make much of a difference. You'll get a much better result and have a much better platform if you just switch to a Z6. The cam will net you power only with tuning, and after that is said and done, you'll have spent enough to buy the swap
Just something to think about.
Old May 5, 2006 | 09:13 AM
EH339's Avatar
What about adding in an LSD to your setup? Why are you in SM in a "stock" hatch?
Old May 5, 2006 | 09:14 AM
1jdmdude8's Avatar
Default Re: best cam to put it stock 94 civic hatch. (EH339)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH339 &raquo;</TD></TR><TR><TD CLASS="quote">If you don't do a whole z6 swap, at least swap the tranny. The Si gearing is more agressive than what you currently have.</TD></TR></TABLE>
that i didn't think of, but if i was going to do that, i might at well throw a flywheel and clutch in it as well?
Old May 5, 2006 | 09:17 AM
1jdmdude8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Just something to think about.</TD></TR></TABLE>
the only reason i dont want to do a swap it cause it would be awsome to beat people with only running this motor, and i would rather built and race, than swap. i like to see progress, and what i can do with stock motors. I used to do a lot with atv's, but cars seam to be a lot more safe, and i can't afford to get hurt on an atv anymore.
Old May 5, 2006 | 09:18 AM
1jdmdude8's Avatar
i am in sm, because of suspension, swaybars, tires. and then the most rediculous part of all is because i have no back seats, and taking a whole 16 pounds or so out bumps you into sm
Old May 5, 2006 | 01:19 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmdude8 &raquo;</TD></TR><TR><TD CLASS="quote">i am in sm, because of suspension, swaybars, tires. and then the most rediculous part of all is because i have no back seats, and taking a whole 16 pounds or so out bumps you into sm</TD></TR></TABLE>
As far as I know, you can remove however much of whatever you want and remain in EP. At least you can here in Ohio...
Old May 5, 2006 | 01:24 PM
-Gary-'s Avatar
Same here in LA.
Old May 27, 2006 | 10:22 AM
1jdmdude8's Avatar
Default Re: best cam to put it stock 94 civic hatch. (scuzz)
not for the scca though, otherwise i'd be set. and every run i take is within 9 thousands of each other at the same track, so i have found the limits for my car. maybe it will be that way in pheonix as well, cause i am moving there in 2 weeks
civicpimp
17
Aug 12, 2005 10:45 AM
hYbRiD EeEkAy
Sep 6, 2003 09:03 PM
maximedx
Feb 4, 2002 09:16 PM
azn_outlaw
Oct 20, 2001 06:44 PM
W0oT
Oct 4, 2001 10:07 AM
