What engine???
Old May 4, 2006 | 09:00 PM
bitz95civ's Avatar
Default What engine???
I looked at a 95 civic coupe tonight that has a engine swap and it says its from an si so it has vtec, but it doesn't say vtec on the top. What engine would this be and approximately what year would it be around? Also for a grind into fifth could this be fixed by changing the tranny fluid to syncromesh? Thanks in advance.
Old May 4, 2006 | 09:06 PM
B18C EG2's Avatar
From: Home Of The Players And PIMPS, IN, united states
Default Re: What engine??? (bitz90teg)
its an SOHC vtec motor from ethier 92-95 si hatchback...those valve covers just had the H with a lil honda under it....
you can sell that motor to the ninja ****** on this site and buy a nicer motor...
Old May 4, 2006 | 09:12 PM
RaceCarRyne's Avatar
Default Re: What engine??? (Stupid EK)
what is a ninja *****?
Old May 5, 2006 | 09:54 AM
bitz95civ's Avatar
Thanks for the help, but for the grind into fifth what would I possibly have to do replace to get it fixed?
Old May 5, 2006 | 10:17 AM
honda_civic1's Avatar
check your tanny fluid lever if its low then put some more tranny fluid in it. if it nots that then you should just get any tranny cause it being a sohc you can find one any where for really cheap.
Old May 5, 2006 | 10:18 AM
snatch's Avatar
Default Re: (honda_civic1)
If the tranny fluid isn't low it's likely a synchro going bad. Best bet is to replace it. Synchromesh will only mask the problem. (although some have said it fixes it for them)
Old May 5, 2006 | 03:08 PM
bitz95civ's Avatar
Default Re: (******)
Thanks a lot for all your help. I am getting the car inspected on monday so if it checks out i'm buying it.
bdmlilburn
Mar 28, 2009 02:03 PM
ef n00b
Dec 8, 2006 11:16 PM
T Rick
Sep 10, 2006 10:03 PM
EJay1
Mar 22, 2006 06:11 PM
Dirt_McgirT
Feb 6, 2003 08:03 AM
