about a grinding tranny ?
1 Post
Re: about a grinding tranny ? (spoon_ek626)
You should do the cheap/easy things first. Did you check your tranny fluid level? maybe u just need tranny fluid. Bleed your clutch. How old is your clutch? Try even changing your tranny fluid, Ive seen that cure problems.
If it keeps grinding after that , u have bad synchros. That will cost u, unless u have a SOHC. What motor do u have?
