Oil Pump for a b20 vtec
can anyone tell me if you know whether i absolutley have to change to oil pump from the stck b20 to a oil pump out of a b16 or b18. i need to know asap because im ready to do the conversion but i need to know this first. i have a b16a. can i use the one off that and put it on the b20 block?
all b series pumps are the same, but it depends what year u use cause the lower timing covers have to be the same year as the pump cause they are slightly different thats all.
well i have just the b20 in my car now and going to 6500 rpms sounds kinda hard on the motor. someone told me that to take it to higher rpms i need a oil pump thats from a vtec motor and used to going into higher rpms. could i just keep the one on it thats already on??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">all b series pumps are the same, but it depends what year u use cause the lower timing covers have to be the same year as the pump cause they are slightly different thats all.</TD></TR></TABLE>
eh, not all true. all 96+(obd2) b-series oil pumps are the same.
id say get a 96+ ls pump with a 96 ls lower timing cover.
that might be the best but is what i want to know is of a 96+ b16a oil pump will work? or if the one in the b20 will work? I dont know what year my b20b is so i dont know what i need to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyTEC4 »</TD></TR><TR><TD CLASS="quote">that might be the best but is what i want to know is of a 96+ b16a oil pump will work? or if the one in the b20 will work? I dont know what year my b20b is so i dont know what i need to do.</TD></TR></TABLE>
yes a 96+ b16 pump will work.
Modified by projectTeG at 5:28 AM 5/5/2006
can you possibly tell me the results of it not being the right one? if its not the right one will vtec not kick or what? the oil pump i want to use is off a 2nd gen b16a?
So anyway, I have read all of your replys, all good info. I'm building a B20 vtec with a motor from a 98, so you guys are all saying that the oil pump in it is fine?
he saying all b series can use the same oil pumps. if ur changing out the old one for a new one, then go with one out of a 96+ vtec motor. if ur block is 96+ and u dont need one then dont get one. like me i have a 94 ls block and got a 00 itr oil pump, water pump, t belt, and jsut notched out the lower timing cover instead of spending $30. either way works fine, and the notching out is super simple
roycivic92
Aug 30, 2007 02:53 PM
showtymers619
Mar 23, 2004 05:49 PM
xaznx
Jul 25, 2002 04:30 AM
