Slave cyl about to fall off!!!!
Old May 4, 2006 | 06:20 PM
SpOoLiNg CiViC's Avatar
Default ****! HELP! slave cyl about to fall off!!!!
OK!! i have dont research... something i need in helicoil... ( if spelled correctly)... well... the 2 screws that hold my slave cycl on are stripped out... so what can i do to keep my slave cycl on? no jb weld or goofy ****.... do i just drill it out a lil over and get a helicoil and put it in there? what is my tranny metal or alum? and what size helicoil would i have to get?
thanks honda tech guys
ben
Old May 4, 2006 | 06:24 PM
Crx Jimmy's Avatar
Default Re: ****! HELP! slave cyl about to fall off!!!! (SpOoLiNg CiViC)
you might be able to get away with going the next bolt size up( which would probably be standard not metric but it shouldnt be a problem) and retapping the hole for those threads and open up the holes in the cylinder a bit so the new bigger bolt fits through
Old May 4, 2006 | 06:27 PM
schardbody's Avatar
thats my suggestion as well, helicoils dont tend to work well in aluminum. you can easily drill the holes out and retap the threads.
Old May 4, 2006 | 06:35 PM
Default Re: (schardbody)
so basically just get a bigger bolt and start it and go.. or i have to take the radiator and fan out and drill it out... (only way to get in there) and go with that.. i think it's a 12mm head but what 5/8 bolt? i am not sure... but what would be the size up?...... if u know off ur head.. i could get it out and bring it to autozone.... or lowes or hardware place.......
Old May 4, 2006 | 06:36 PM
Default Re: ****! HELP! slave cyl about to fall off!!!! (Crx Jimmy)
it will not expletive up my transmission if i drill in it.... right? cuz it's alum wont crack?
Old May 4, 2006 | 06:38 PM
schardbody's Avatar
you will need to use a right angle drill or remove the radiator and fan to drill it (unless you wanna drop the tranny) then get the correct drill bit for the size it will be tapped to. you cant use the bolt to make new threads, you will have to tap them out w/ a thead tap. no clue on the bolt size, but it doesnt really matter.
Old May 5, 2006 | 06:18 AM
qat727's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpOoLiNg CiViC &raquo;</TD></TR><TR><TD CLASS="quote">it will not expletive up my transmission if i drill in it.... right? cuz it's alum wont crack? </TD></TR></TABLE>
If you do it right, it shouldn't. What schardbody said is a pretty good way of doing it, but it can't hurt to keep the metal cool while you're drilling it. Just be careful and don't try to go too fast.
Old May 5, 2006 | 06:21 AM
tatmark1's Avatar
helicoil is your first option if it dont work tap to next size up.
it will work fine. go to a machine shop and ask what they would do if you had a stripped out spark plug hole...helicoil. if done right it will be just as good as before.
and when you put it back together use antisieze
do it just like this...
http://www.atvconnection.com/e...3.htm
Modified by tatmark1 at 11:13 AM 5/5/2006
Modified by tatmark1 at 1:14 PM 5/5/2006
Old May 5, 2006 | 09:38 AM
schardbody's Avatar
helicoil does not hold in aluminum though.
Old May 5, 2006 | 09:44 AM
tatmark1's Avatar
well i dont know who does yours but they must be doing them wrong
i have had 2 alum heads with spark plugs repaired with heli coil...worked great, plus helicoiled other things and didnt have any problems
Old May 5, 2006 | 04:21 PM
schardbody's Avatar
i do all my own work, and true i guess they could hold, i just dont see how. i havent tried it but a couple times on a 5hp briggs block, and they wouldnt hold.
Old May 5, 2006 | 05:05 PM
tatmark1's Avatar
i dont think the casting / metal quality are the same ...but we can agree to disagree.
in his case this would be a better first option then drilling and retapping as last resort
Old May 5, 2006 | 05:49 PM
schardbody's Avatar
I dont know, just from my experience helicoils wouldnt hold in the aluminum, i guess if its been done and works then i just suck. problem i have had w/ it is the helicoil not sticking into the newly tapped threads, and therefore the hole just ends up bigger.
zach1288
Sep 3, 2009 12:17 PM
Luckywhiteboi
Mar 6, 2009 03:58 AM
dan89crxsi
24
May 18, 2008 10:25 AM
snzh22
Apr 28, 2008 05:13 AM
