B16b passing smog in CA
Old May 4, 2006 | 03:07 PM
B16b-EJ8's Avatar
Default B16b passing smog in CA
Anyone know how to get a CTR motor to pass the emissions test in ca? I'm getting ready to drop it into my car and will be needing the info soon enough.
Old May 5, 2006 | 10:34 AM
crxsirvtec's Avatar
Default Re: B16b passing smog in CA (ProjectNoob)
should just need a good CAT and run lots of gas line antifreeze..
what we do in Ontario
also having a chipped ecu, programmed just for the e-test(smog test)
http://www.racingchips.com will do that...
Old May 5, 2006 | 02:53 PM
B16b-EJ8's Avatar
Default Re: B16b passing smog in CA (crxsirvtec)
Thanks...do you guys have trict testingup there?
Old May 6, 2006 | 05:21 AM
crxsirvtec's Avatar
like using another car for the test and putting a different VIN in the computer??
Old May 10, 2006 | 07:42 AM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectNoob &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know how to get a CTR motor to pass the emissions test in ca? </TD></TR></TABLE>
[b] Easy!
Old May 10, 2006 | 09:38 AM
B16b-EJ8's Avatar
Default Re: B16b passing smog in CA (hazw8st)
How easy? Some one told me that because there is no USDM counter part it would be hard to get it BAR'd. I noticed that you have provided lots of great info on this subject to many people on here. Email me with some info when you have time. The Motor is not in my car yet but will be in the next couple of weeks. Do i need to take it to the smog reff right after that or wait till they tell me i need to go (sorry i just moved to socal about a year ago so im not to sure how it works.
Thanks
Old May 10, 2006 | 12:04 PM
TEST ONLY's Avatar
Why would you even consider reffing this vehicle? Unless your vehicle is all riced out, you have a ton of cash to spend or you happen to suffer from paranoid (black & white fever) panic attacks, just swap it and leave it alone. Public internet forums are full of unbased opinions and preconceived notions. Reffing a vehicle isn't for everybody. Double-check your sources and do some more research before you bend over backwards and ref this vehicle. PM me for more info. Good luck....
Old May 10, 2006 | 02:23 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazw8st &raquo;</TD></TR><TR><TD CLASS="quote">Why would you even consider reffing this vehicle? Unless your vehicle is all riced out, you have a ton of cash to spend or you happen to suffer from paranoid (black & white fever) panic attacks, just swap it and leave it alone. Public internet forums are full of unbased opinions and preconceived notions. Reffing a vehicle isn't for everybody. Double-check your sources and do some more research before you bend over backwards and ref this vehicle. PM me for more info. Good luck....</TD></TR></TABLE>
Im' new to California so im not sure how its done...I thought that if a swap was done youhad to take it to a ref and get it passed. True/not True? The vehicle is not riced out no Jungle fever...Just didnt know i could leave it alone.
Old May 10, 2006 | 04:48 PM
TEST ONLY's Avatar
Hit me up via email......
piggydog
May 16, 2006 07:32 PM
plusONE jboy
Apr 27, 2005 06:07 AM
neoburi
May 10, 2003 10:33 AM
MikeyDB7
Apr 18, 2003 06:30 AM
ghettols
10
May 21, 2002 11:58 AM
