Need help with motor setup(Turbo guru's help!!)
Old May 4, 2006 | 01:40 PM
G2K's Avatar
G2K
Default Need help with motor setup(Turbo guru's help!!)
Alright so it goes with out saying you need the info, so here it is.
Chassis:
1993 Integra GS-R
Motor:
LS Block Golden Eagle Sleeved
B17A Head - R&D Dyno CNC Ported
ARP Head Studs
ARP Main Studs
87.2m GSR Crank/Balanced
Manley TurboTuff Rods/ GSR
CP 84mm/9.0 Compression
Rocket Motorsports m22x Cams
Rocket Motorsports Springs & Retainers
BDL Cam Gears
BDL Fuel Rail
Victor X Intake Manifold
RS Machines 70mm Throttle Body
ITR Oil Pump
ITR Water Pump
Golden Eagle LS/Vtec Conversion Kit
Nuekin RamHorn Manifold
Tial 44mm Wastegate
So to those Turbo Guru's out there what it my best choice for a turbo on this set up. The goal for this car is mid 10's in full street trim. I've been told that I could use either a SC61 or a GT35R and make over 600whp.
Thanks for any input.
Tristan
Old May 4, 2006 | 01:46 PM
spoolinyo's Avatar
t3/t67 HO or gt35 R
Old May 4, 2006 | 01:49 PM
Fitti's Avatar
Default Re: (liftedyO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liftedyO &raquo;</TD></TR><TR><TD CLASS="quote">t3/t67 HO or gt35 R</TD></TR></TABLE>
He said turbo guru's (liftedyo). What kind of name is that for a drag racer. Maybe it should be spoolinyo well at least for a turbo guru.
Old May 4, 2006 | 04:36 PM
MrParks's Avatar
Default Re: Need help with motor setup(Turbo guru's help!!) (DooDoo Brown Racing)
ITS T66 D/BB OR A GAREETT GT4088R OR TURBONETICS T70 WITH BB OPTION BEST SIUTS THAT MOTOR. IF YOU WANT A FASTER SPOOL 35R IS A GREAT CHOICE BUT IF YOUR DRAG RACING T66 FITTS RIGHT INTO THE PACKAGE
Old May 4, 2006 | 05:18 PM
fknfast's Avatar
Default Re: Need help with motor setup(Turbo guru's help!!) (GHOSTWORKS)
35r
Old May 5, 2006 | 09:01 AM
G2K's Avatar
G2K
Default Re: Need help with motor setup(Turbo guru's help!!) (fknfast)
Thanks for all the info so far, I was wondering if arturbo or tony wanted to chime in on with something? BTW the car has a full 3" downpipe and exhaust and a precision 650hp intercooler.
Thanks again.
Tristan
Old May 5, 2006 | 09:11 AM
boostedcivicsir's Avatar
Mr. Badwrench
seeing the power my t3t67 h.o. just put down, that gets my vote.
Old May 5, 2006 | 09:36 AM
Hybrid_Coupe's Avatar
im puttin a word in for my turbo pt67...going strong and nowhere near maxed out on my car
Old May 5, 2006 | 01:28 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GHOSTWORKS &raquo;</TD></TR><TR><TD CLASS="quote">ITS T66 D/BB OR A GAREETT GT4088R OR TURBONETICS T70 WITH BB OPTION BEST SIUTS THAT MOTOR. IF YOU WANT A FASTER SPOOL 35R IS A GREAT CHOICE BUT IF YOUR DRAG RACING T66 FITTS RIGHT INTO THE PACKAGE</TD></TR></TABLE>
A 35R will make almost as much horsepower as a T66 and spool quicker. T70's are too surge prone, and I would much rather have a T67 comp wheel over the T66 or T70 if he wants something big.
Old May 6, 2006 | 06:34 AM
G2K's Avatar
G2K
Default Re: Need help with motor setup(Turbo guru's help!!) (b16sedan)
Thanks again for the help and input, I've talked to a few other people offline, and alot of people point towards the PT67. So we're gonna try it out and see what happens.
Thanks again.
Tristan
Old May 6, 2006 | 06:58 AM
tony1's Avatar
Old May 6, 2006 | 09:11 AM
Tuned1's Avatar
Default Re: Need help with motor setup(Turbo guru's help!!) (tony1)
pt67 here
dropped93ex
Oct 2, 2011 06:11 AM
Thasickzda
Apr 3, 2011 07:54 AM
fracas
Feb 16, 2007 05:44 PM
koolaid3246
May 9, 2006 05:42 PM
B18Sleeper
Sep 24, 2005 11:02 AM
