Lower suspension crown nut removal
Old May 4, 2006 | 08:31 AM
lonefuzzy79's Avatar
Default Lower suspension crown nut removal
I found that when I was dismantleing my suspension that the lower crown nut/bolt assembly was damaged in that the bolt was broken off where the cotter pin is supposed to be. I think I should replace this before driving too hard on it, honda put it there for a reason. I tried removing the hub from the lower a-arm with a hammer, that did not work. I need to know how you all remove the hub from the A-arm, and then would that bolt need to be pressed out or can I just whack it out? Thanks all.
SummerTaz
Dec 6, 2006 04:03 PM
unhappy_idle
May 16, 2006 09:22 AM
neopheus
Mar 18, 2005 10:53 PM
CXHatchback
Jun 5, 2003 09:22 PM
Tommy_Gunns
Jan 18, 2002 12:42 PM
