stripped oil squirters
Old May 3, 2006 | 12:53 PM
slowassciv33's Avatar
Default stripped oil squirters
i just got a call form the machine shop..they told me they where gonna hot tank my ,motor and had to remove the oil squirters. but in the process of removing the screws the threads came out wit the screws..and said it can not be fixed..is this true or they tryin to bullshit me cause they want me to bring another block down like i can pull on out of my ***..i need help i saved up for this motor and the past and now they are tellin me its no good
Old May 3, 2006 | 12:58 PM
dragonz04's Avatar
Default Re: stripped oil squirters (slowassciv33)
that is hella Fu Ck'd up ****, I think they should be held liable for whatever they screwed up on at their machine shop
Old May 3, 2006 | 01:02 PM
( o )( o )'s Avatar
can they be "heli-coiled"?
Old May 3, 2006 | 01:07 PM
Default Re: stripped oil squirters (( o )( o ))
im not sure they just told me it cant be fixed..but other people told me the should be able to tap it with a reamer.....
Old May 3, 2006 | 01:11 PM
DonF's Avatar
There is not heli-coil kit for that size. Have them tap it to 1/8 pipe and plug them. Unless you are going to boost to 30 PSI.
Old May 3, 2006 | 02:35 PM
Default Re: stripped oil squirters (DonF)
will plugin them up be fine?? its a gsr block
Old May 3, 2006 | 02:53 PM
non-VTEC's Avatar
plugging them up is fine......lots of other honda engines run without oil squirters with no problems.
the squirters are there to help cool the piston down...so they may run a little hotter than normal but nothing that should cause an engine falure unless you plan to boost the **** out of that motor on stock pistons.
Old May 3, 2006 | 06:02 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 &raquo;</TD></TR><TR><TD CLASS="quote">will plugin them up be fine?? its a gsr block </TD></TR></TABLE>
I plug my oil squirters in all of my blocks. I also run forged pistons.
Old May 3, 2006 | 07:07 PM
Default Re: stripped oil squirters (b19coupe)
what if im not runni forged???
Old May 3, 2006 | 10:06 PM
dinko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 &raquo;</TD></TR><TR><TD CLASS="quote">what if im not runni forged???</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">plugging them up is fine......lots of other honda engines run without oil squirters with no problems.
the squirters are there to help cool the piston down...so they may run a little hotter than normal but nothing that should cause an engine falure unless you plan to boost the **** out of that motor on stock pistons.</TD></TR></TABLE>
Old May 4, 2006 | 05:50 AM
b19coupe's Avatar
You will still be o.k. As long as you don't run the motor super lean or boost the crap out of it.
Old May 4, 2006 | 05:57 AM
onefstek's Avatar
just block them off. I run my turbo motor with blocked off squirters.
rustlude87
Oct 10, 2009 11:21 PM
totsie7944
Apr 4, 2008 05:02 AM
mtownsi
Mar 24, 2008 02:27 PM
Mr HYDE
Jul 12, 2005 06:31 PM
ntegls
Dec 28, 2003 10:26 AM
