05-06 rsx type s skunk 2 coils problem NEED HELP
i know i had to cut off the sleeves and the bottom of the spring holder but what else do i need to cut off....it still is making noise when i drive....wtf.....i need help if not...then imma look for a trade + cash for some damper kits...thanks...
you mean the bump stop?
yea, youre supposed to cut them to compensate for the lower spring. just search on http://www.clubrsx.com. btw, get some good shocks before yours blow out.
no...its not the bump stops...i already cut them too...it sounds like something is really loose somewhere??? can anyone help??
There are these rubber band type deals that should have come with your kit, if you did not put the right size or enough of them on, the sleeve that has the adjustable spring purch will rattle aroung your strut/shock body.
