need help on spring!
i just installed tein S-tech spring on my S. the ride is very good and some improvement on the handling, but it's making some funny sound when i hit the speed bump or pothole (slowly, really slow) any idea why? is t my shock? or the spring?
thanks
thanks
check the 14mm bolt in the rear that holds the link pin to the sway bar, people take them of when doin springs, and dont tighten the bolt tight enough
well it wasn't the bold though, i was the stabilizer on the front right side... i'd figure that out.. but still don't know what made the car sit not evenly...
Weird. I have them on my car for the time being and don't have that noise. Have you checked how they were installed (if u didnt do them yourself)? Check and make sure they're seated properly on the shock. Also, did they put the bump stops back in all the way around? You're supposed to also trim them slightly according to the directions that comes with it. Maybe they/you left one out.
solex
Honda Civic (2001 - 2005)
28
Oct 16, 2010 05:48 PM
