2000 si tranny grinding
Old May 3, 2006 | 08:49 AM
mtny's Avatar
Default 2000 si tranny grinding
My em1 just started grinding today when I switch from 3rd to 4th anywhere from 3k-5k rpms... Why did it do this and what do I need to do to fix it?
Old May 3, 2006 | 09:11 AM
aquabob89's Avatar
* B A N N E D *
Default Re: 2000 si tranny grinding (mtny)
try replacing your trans. fluid with some good gear lube. honda, mtf. redline racing. gm syncromesh.
Old May 3, 2006 | 10:57 AM
mmbonbons's Avatar
Default Re: 2000 si tranny grinding (aquabob89)
gm friction modifier and pennzoil synchomesh helped cure it on my car.
Old May 3, 2006 | 11:04 AM
killerformula's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquabob89 &raquo;</TD></TR><TR><TD CLASS="quote">try replacing your trans. </TD></TR></TABLE>
FTW
Old May 3, 2006 | 11:37 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: 2000 si tranny grinding (killerformula)
Synchromesh FTW!!!
Old May 3, 2006 | 11:42 AM
civic93@8psi's Avatar
its a common prob in 99 n 00 si's gm syncromesh does help tho
i work at a honda dealership and so many si's had this prob that i thoughr honda was going to make it a recall, but they didnt. i belive we cahaned 3rd and 5th gears and syncros on all the ones that came thru here
Old May 3, 2006 | 04:22 PM
mtny's Avatar
Default Re: (civic93@8psi)
Awesome, well I bought 2 qts. of GM Synchromesh yesterday (b4 it started). Tomorrow I'm getting it serviced and hes gonna put it in. Hopefully it will fix it.
Old May 3, 2006 | 06:18 PM
JDM B16A's Avatar
Default Re: (mtny)
GM SYNCHROMESH THIS GM SYNCHROMESH THAT!! Enough with that already. Some goddamn synchromesh isn't going to add teeth to your SYNCHROS!! What you need to do is repalce your tranny or rebuild it. That synchromesh is only going to cure that grind for about 2k miles and you're back to square one again. I suggest to just buy a cheap tranny..like an LS or something and slap it onto your B16. That is if you're only using it for daily driving.
Old May 3, 2006 | 06:20 PM
E46Kid's Avatar
Rebuild the b16 tranny! Your Synchros are wearing out!
beak's Avatar
Use Honda MTF. Don't bother with the other junk.
Old May 3, 2006 | 08:11 PM
hobbitz007's Avatar
nah....hands down with syncromesh.....but what do I know? IMA NEWBIE
Old May 4, 2006 | 04:59 AM
mtny's Avatar
Default Re: (JDM B16A)
I want a new tranny but if I do that I'll have to get an lsd and clutch so I'll wait.
Old May 4, 2006 | 05:00 AM
mtny's Avatar
Default Re: (EkSi)
How much to rebuild?
Old May 4, 2006 | 08:04 AM
beak's Avatar
Default Re: (hobbitz007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hobbitz007 &raquo;</TD></TR><TR><TD CLASS="quote">nah....hands down with syncromesh.....but what do I know? IMA NEWBIE</TD></TR></TABLE>
Agreed.
Old May 4, 2006 | 09:39 AM
SiRMike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquabob89 &raquo;</TD></TR><TR><TD CLASS="quote">try replacing your trans. fluid with some good gear lube. honda, mtf. redline racing. gm syncromesh.</TD></TR></TABLE>
No don't bother with redline...I used that before in my tranny and was not happy with it what so ever. I'm now using Motul 10w30 gear oil...been fine so far.
I've heard good things about the GM syncromesh.
Modified by SiRMike at 12:11 AM 5/5/2006
Old May 4, 2006 | 02:15 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 2:25 PM 11/16/2006
Old May 4, 2006 | 08:56 PM
mtny's Avatar
Default Re: 2000 si tranny grinding (schlit)
I just got the car. I'm not an idiot who abuses my ****. Thanks!
Old May 4, 2006 | 09:09 PM
E46Kid's Avatar
Dont wanna thread jack but i had a question that came across my mind. Has anyone used the synchromesh after the 2k miles are up and keep using it over and over instead of fixing the syncrhos?? would it make the car run worse when its returning back to the griding or is this a cover up like what was said
Old May 5, 2006 | 08:11 AM
CardDealer's Avatar
Banned
Old May 6, 2006 | 06:58 AM
mtny's Avatar
Your an idiot. Thanks for your help d00d!!!!
Old May 6, 2006 | 09:46 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 2:24 PM 11/16/2006
boomersz
Feb 26, 2007 06:08 PM
grey_ls_nuka
Oct 10, 2005 09:17 PM
trooper0641
18
May 6, 2005 06:50 PM
hatchedzex
Aug 10, 2004 06:30 AM
el arbi
Nov 5, 2003 05:59 AM
