15's messin up?? weird, am i stupid??
Old May 3, 2006 | 07:01 AM
craftysince86's Avatar
Default 15's messin up?? weird, am i stupid??
ok so i got two kicker cv-r 15's (i think thats what they are), old school rockford fosgate 900 competition amp, the lil black ones and a 3 farad cap... now the weird thing is that used to hit perfect, and i disconnected once and then when i went back to hook them up they wouldn't hit?? so i figured out that the remote was meesed up fixied it and now the amp turns on, the 15's hit fine when the volume is very low, but once u turn it up the bass hits like really hard and goes like "boom, boom, boom, boom" constantly, really fast (what? it's only way i could think of explain it) everything is hooked fine the wires are where they sposed to be rca's and power on opposite sides, everything connected to amp good and to speakers too, it's weird i don't know what the hell is going on with it?? help!!
Old May 3, 2006 | 10:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: 15's messin up?? weird, am i stupid?? (*****yeyedemcee)
Recheck the ground for the amp. 94
Old May 3, 2006 | 10:45 AM
Depeche's Avatar
Default Re: 15's messin up?? weird, am i stupid?? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Recheck the ground for the amp. 94</TD></TR></TABLE>
Thats all I can think of. You can check and make sure that no part of your power lead is touching a metal part on your amp as well. Its hard to diagnose these types(non-common problems) of things without being able to look at the setup in person in my opinion.
Old May 3, 2006 | 02:08 PM
Default Re: 15's messin up?? weird, am i stupid?? (Depeche)
alright so i checked the ground and it's fine, i tried changing rca's with three different sets, checked all the wires again and i still can't figure it out?? i don't know any ideas??
Old May 3, 2006 | 02:13 PM
rcurley55's Avatar
New User
take the cap out of the system temporarily....
Old May 5, 2006 | 07:49 AM
Default Re: (rcurley55)
just take it out and leave it off?? will i be able to put it back on or should i just run it directly to the amp?? someone told me that it's possible that the rca jack got messed up and i needed to change the deck or put in rca converters because the rca's in the back of the deck or messed up??
Old May 6, 2006 | 11:11 AM
mhart's Avatar
i had almost the same problem, mine was cause the rca's where touching the amp. i had cheaper rca's with metal ends and the ends where laying on the amp, which was a rockford amp. also i dont think its power related cause its playing, its rca related, good luck.
Old May 7, 2006 | 03:36 PM
midoublez's Avatar
b sure rca cables and all power cables are not too close together, such as tangled. sometimes if they r running side by side it could cause that. also check rca cables to see if they are not damaged. and r pulgged in all the way.
Old May 8, 2006 | 07:43 AM
Default Re: 15's messin up?? weird, am i stupid?? (midoublez)
i found it!! it was the rca jack from the deck, i don't know what happened but i just switched out decks and it worked perfect... thanks anyways people
Old May 10, 2006 | 04:22 PM
midoublez's Avatar
no problem
Jdeno148
Audio / Security / Video
May 4, 2009 07:03 AM
thejacka
May 29, 2006 03:54 PM
idriveadelsol7
Jul 6, 2005 06:28 PM
hometheaterman
12
May 23, 2005 09:32 AM
AaronJ
Apr 1, 2004 01:10 PM
