need expert advice.
Old Jul 6, 2005 | 02:26 AM
idriveadelsol7's Avatar
Default need expert advice.
is there any way i can check how many ohms/rms wattage my amplifier is pushing to my subwoofer? i wired it DVC to 2 ohms (600w RMS x 2) but the thing is, it's sounds weird; like my i wired the incorrectly.
Old Jul 6, 2005 | 08:31 AM
fcm's Avatar
fcm
Old Fart
Default Re: need expert advice. (idriveadelsol7)
What amp, what sub, and how have you got the DVCs wired, also what do you mean "sounds weired" 94
Old Jul 6, 2005 | 11:16 AM
precision power dcx 1000.1
eclipse 12" sw7124-t4
Old Jul 6, 2005 | 01:06 PM
nsxxtreme's Avatar
You probably wired one of the coils out of phase. Try switching around one set of wires.
Old Jul 6, 2005 | 02:08 PM
Dan04Accord's Avatar
Use an ohm meter... disconnect the sub leads from the subs and measure the resistance with a multi meter. This will also confirm the phase is correct. Electricity takes the path of least resistance so if you wire it 2 ohm, your amp will run at 2 ohm (or clip and shut off).
It sounds like one or more of your voice coils is out of phase, and that needs to be corrected post haste.
Old Jul 6, 2005 | 03:07 PM
nsxxtreme's Avatar
Default Re: need expert advice. (Dan04Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan04Accord &raquo;</TD></TR><TR><TD CLASS="quote">This will also confirm the phase is correct. </TD></TR></TABLE>
Please explain?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan04Accord &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like one or more of your voice coils is out of phase, and that needs to be corrected post haste.</TD></TR></TABLE>
If both coils were out of phase with the source they would be in phase with each other.
Old Jul 6, 2005 | 03:24 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">precision power dcx 1000.1
eclipse 12" sw7124-t4</TD></TR></TABLE> Your amp is 400 watts into 4 ohms 600 watts into 2 ohms and 1000 watts into 1 ohm, it is stable at one ohm.
Your sub is a DVC 4 ohm sub and 450 watts RMS, continues and 900 watt max.
I would wire the VCs on the sub in parallel for a 2 ohm load, that way you have 600 watts of RMS power out of the amp, better to be overpowered then underpowered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan04Accord &raquo;</TD></TR><TR><TD CLASS="quote">Use an ohm meter... disconnect the sub leads from the subs and measure the resistance with a multi meter. This will also confirm the phase is correct. Electricity takes the path of least resistance so if you wire it 2 ohm, your amp will run at 2 ohm (or clip and shut off).
It sounds like one or more of your voice coils is out of phase, and that needs to be corrected post haste.</TD></TR></TABLE>What?
nexxtreme is probably right.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">You probably wired one of the coils out of phase. Try switching around one set of wires.</TD></TR></TABLE> check and see, I would also check the power and ground connections to the amp. 94
Old Jul 6, 2005 | 06:28 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan04Accord &raquo;</TD></TR><TR><TD CLASS="quote">This will also confirm the phase is correct.</TD></TR></TABLE>
no i dont think it will but thanks for coming out.
ws350z
Audio / Security / Video
Sep 26, 2008 09:35 PM
craftysince86
May 10, 2006 04:22 PM
{Powered by VIII}
27
Jan 15, 2006 09:10 AM
Orpheus1985
Jul 31, 2005 04:11 PM
icechimpe
Apr 25, 2004 05:02 PM
