Speaker Power Help
Old May 28, 2006 | 01:18 AM
thejacka's Avatar
Default Speaker Power Help
Hey, I have the Diamond D361 and they are rated at 60 watts RMS. I have a Diamond D3 400.4 that pushes 57 watts RMS each into 4 channels. My question is what is the most amount of watts I can put to these speakers with careful gain control?
Old May 28, 2006 | 05:25 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Speaker Power Help (thejacka)
You can run just about any amp on them. I recall a while back someone was using Precision Power 1000w amps on the mids' and highs'.
Old May 28, 2006 | 09:07 AM
94_DC4's Avatar
That should be enough but crossover point is more important to me.
Old May 28, 2006 | 09:32 AM
fcm's Avatar
fcm
Old Fart
Although the amp will run the speakers no problem, it is a little "underpowered" but as long as you do not drive the amp into clipping constantly, you should have no problem. 94
Old May 28, 2006 | 12:36 PM
thejacka's Avatar
Whoops I should rephrase my questions. Will I be able to put an amp that puts out like 75-100 watts RMS onto the speakers?
Old May 28, 2006 | 02:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: (thejacka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thejacka &raquo;</TD></TR><TR><TD CLASS="quote">Whoops I should rephrase my questions. Will I be able to put an amp that puts out like 75-100 watts RMS onto the speakers?</TD></TR></TABLE> Yes you can, and you will be better off if you do, you are less likely to drive the amp into clipping, but you will also have to be careful not to put 75-100 watts into the 60W speakers continuously, that will burn up the VCs just as fast as a continuously clipping amp will, just back off on the gain on the amp a little bit. 94
Old May 28, 2006 | 11:12 PM
thejacka's Avatar
ahh.. cool. well recently my front right tweeter stopped working for some reason. i might replace my frontstage with the HEX S600s/s600a. do you think they will be able to handle 182 watts RMS? I plan to bridge my d3 400.4 and power my rear stage with my headunit
Old May 29, 2006 | 07:19 AM
fcm's Avatar
fcm
Old Fart
Do you have a link to the amp and speakers? 94
Old May 29, 2006 | 09:32 AM
thejacka's Avatar
Amp: http://www.diamondaudio.com/pr...model=
They are actually 182 x 2 at 4 ohms according to my manual.
Speakers:
S600a/S600s
Old May 29, 2006 | 03:54 PM
fcm's Avatar
fcm
Old Fart
It should work just fine. 94
TANKE92113
Audio / Security / Video
12
Feb 6, 2007 01:59 PM
cilvia
Mar 7, 2006 10:51 AM
GZERO
Dec 3, 2005 11:58 PM
PiNoYxRaCeRxRH88
11
Nov 26, 2005 10:35 AM
b18c1995
Dec 27, 2004 07:20 AM
