TB question (swapped out H23 for H22A4)
Old May 2, 2006 | 06:27 AM
NoVALude's Avatar
Default TB question/ MAP Sensor (swapped out H23 for H22A4)
I have the H22A4 in the car now and used the TB that came with it (5th gen.), which has the MAP sensor and TPS sensors attached to it. However, the MAP sensor is located on the firewall for the 4th gen. and I am not sure which one I can use....
Do I have to extend the wires from the firewall to run to the TB MAP sensor, or just use the existing one?
Old May 2, 2006 | 06:40 AM
mgags7's Avatar
honestly it doesnt matter which you use
Old May 2, 2006 | 06:42 AM
NoVALude's Avatar
Default Re: (mgags7)
only thing I was thinking about was the fact that there is a hole on the top of the TB where the MAP sensor goes, so there is a MAP sensor attached there ... and I still have the one attached to the firewall.....didn't want a weak spot in the vacuum system (if that makes sense)...
Old May 2, 2006 | 06:50 AM
mgags7's Avatar
as long as the sensor on top of the tb is there, or something is plugging its hole, it will be ok....if you have unused vacuum ports, just get some plugs and pop em on
Old May 2, 2006 | 06:52 AM
NoVALude's Avatar
Raven2201
Jun 5, 2013 01:19 PM
zapzach
Apr 30, 2013 09:45 AM
droppedeg6hatch
Jan 9, 2008 07:38 PM
ALL MOTOR DA
Jun 8, 2006 05:58 PM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
