Oil pressure sensor d16y8
Old May 1, 2006 | 05:40 PM
MBlake55's Avatar
Default Oil pressure sensor d16y8
I need to kno where i can check for my oil pressure on my 97 civic ex d16y8 b/c i just boosted it and now it has really low oil pressure. I was told that it was on the back of the block above the oil filter but i cant find it or its in a different spot any help or opinions would def help thanks
Old May 1, 2006 | 06:45 PM
EX-T's Avatar
Default Re: Oil pressure sensor d16y8 (MBlake55)
It's above the oil filter on the back of the block. There is a black rubber grommet that covers it up.
Where to you give the turbo it's oil supply if you didn't tap into the oil pressure sensor?
Old May 2, 2006 | 07:04 AM
MBlake55's Avatar
Default Re: Oil pressure sensor d16y8 (EX-T)
fresh oil comes from the oil sandwich adapter btw/ the block and the oil filter thanx for the input p.s. if i run my stock cat will that take away a lot of power b/c of restriction? thanx
Old May 2, 2006 | 07:37 AM
I3ooS710's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MBlake55 &raquo;</TD></TR><TR><TD CLASS="quote">fresh oil comes from the oil sandwich adapter btw/ the block and the oil filter thanx for the input p.s. if i run my stock cat will that take away a lot of power b/c of restriction? thanx</TD></TR></TABLE>
Yes, the stock cat will restrict power. Just curious, what kind of turbo kit are you running?
Old May 2, 2006 | 12:13 PM
MBlake55's Avatar
Default Re: Oil pressure sensor d16y8 (I3ooS710)
garret t28 ball bearing w/ like 5-7 pounds of boost
Old May 2, 2006 | 04:58 PM
EX-T's Avatar
You probably can't see the oil pressure sensor b/c of the sandwich adaptor. It probably sticks out further than the sensor does so it's blocking your view.
Old May 3, 2006 | 06:19 AM
MBlake55's Avatar
ya thats prolly tru i gotta take a better look at it b/c its at my buddies shop right now and i only get over there as much as i can too look at it thanx for all the help tho and the input
Shadly
Aug 2, 2011 06:53 PM
Frost7177
Dec 31, 2006 12:24 PM
jdmteg96
Jul 4, 2006 04:22 AM
MBlake55
May 2, 2006 06:47 PM
92accordEX4life
Jan 17, 2006 05:30 PM
