Is this collector ok?
Bought this for super cheap and basically i'm wondering if that burn though is going to be a problem. I'm calling it burn though, I dunno what you guys call it
It's only tacked together and needs to be tigged up.
Thanks guys
Mark
Thanks guys
Mark
I would build another one , and use low heat so you dont burn through and get the "moon rocks" on the inside , just take your time and work on the fitment , the better the fit the better and nicer the weld will be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEEYOND »</TD></TR><TR><TD CLASS="quote">need to practice.....more ... this collector need not to be used unless fixed by a pro....
Why or it will explode?
That burn through isn't bad; I've fixed worse and never had a problem
Its a bit tricker to do it on a Tig but a Mig would fix that in a jiff. Then use a grinder to re-shape it and you're set!
</TD></TR></TABLE>Why or it will explode?
Thanks for the replies.
Somebody local to me will be making the manifold, so i'll leave it upto him weather he wants to use it or fab up another one.
I'll post pics one it's all done.. probably won't be for a while.
Mark
Mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">I would build another one , and use low heat so you dont burn through and get the "moon rocks" on the inside , just take your time and work on the fitment , the better the fit the better and nicer the weld will be
hahaha moon rocks, that's awesome, i've only ever heard it referred to as sugaring. (i believe that's the asme term for contamination due to exposure to unshielded ozone on the back side of a weld due to too much goddamn heat.)
</TD></TR></TABLE>hahaha moon rocks, that's awesome, i've only ever heard it referred to as sugaring. (i believe that's the asme term for contamination due to exposure to unshielded ozone on the back side of a weld due to too much goddamn heat.)
91-lsvtecsi
Nov 11, 2011 03:28 PM
Touge Factory
30
Aug 12, 2011 04:58 PM
