help me!
Old May 1, 2006 | 11:28 AM
89 crix si's Avatar
Default help me!
i have an 89 crx si with an a6/y8 mini me swap. pm6 ecu with 1 wire vtec. the car will just die while im driving. like on the highway, ill be going...then the i can feel the car lose power. as soon as it dies it'll start right back up. sometimes it will be fine, and sometimes it will die 5-10 times back to back. i have no clue whats goin on with it, so any help would be appreciated. thanks
Old May 1, 2006 | 12:08 PM
thesmogman's Avatar
Default Re: help me! (89 crix si)
Sounds like fuel filter is plugged up. If you haven't replaced it I would start there.
You could check the fuel pressure 1st but a filter is only $10 and 15 minutes to try.
Old May 1, 2006 | 12:23 PM
89 crix si's Avatar
Default Re: help me! (thesmogman)
great. thanks man, anyone else have some suggestions?
Old May 1, 2006 | 04:01 PM
mahatma's Avatar
Take off the distributor cap and check the rotor & cap.....
Also might want to take off the distributor itself, give it a twist by hand to make sure the bearing isn't binding.
Old May 1, 2006 | 05:19 PM
89 crix si's Avatar
Default Re: help me! (mahatma)
ive replaced the cap, rotor, dizzy already. keep em coming guys. thanks for the help
Old May 9, 2006 | 01:07 PM
89 crix si's Avatar
brand new battery and fuel filter installed... and.......still dies! anymore ideas?
Old May 9, 2006 | 06:08 PM
89 crix si's Avatar
the other day i gunned it in first, and half way through the gear it felt like i slammed into a wall. its like it hit a rev limiter, then i had to wait for the revs to drop, then restart it. it started right back up. i dont get it.
Old May 10, 2006 | 12:25 PM
89 crix si's Avatar
Old May 11, 2006 | 11:59 AM
89 crix si's Avatar
help
Old May 16, 2006 | 05:09 PM
89 crix si's Avatar
still need help
Old May 16, 2006 | 06:07 PM
Phshorty's Avatar
did you check your main relay?
Old May 17, 2006 | 02:02 AM
89 crix si's Avatar
Default Re: help me! (Phshorty)
no, but ill check that next. thanks
Old May 22, 2006 | 04:47 PM
89 crix si's Avatar
main relay fixed it
Old Jun 27, 2006 | 10:00 PM
court's Avatar
25 Year Member
so you replaced the main relay and everything works fine?
Old Jun 27, 2006 | 10:07 PM
EF_ST@TUS's Avatar
Make sure battery terminals arent touching any metal.....
bdan629
Sep 30, 2013 11:26 AM
89 crix si
May 23, 2006 01:33 PM
CIVIC dude
Sep 13, 2003 01:27 PM
thashadow
Jun 11, 2002 03:43 PM
