Leaking oil
Ok so the problem is i had a blown head gasket so i changed it and got the head resufaced just to be safe and when i started it it began to leak oil under the vtec solinoid where the head and the block meet i know i torque the head right to correct ft/lbs an sequence so can anyone help
i replaced the dizzy o-ring and cam plug before oil stop showing up on that corner of the block, if any gasket on that side of the head is leaking it will end up there, or worst case your block is warped
did all that work and couldnt even take a straight edge and some feeler gauges to the block? i quess you used old head bolts too?
how did you prepare or clean deck before putting new gasket and head back on?
saemoonyang
12
Jun 7, 2010 02:01 PM
pooRmansss
Feb 19, 2009 03:24 PM
