OBD1 ignition timing question
Old May 1, 2006 | 06:26 AM
SETI20's Avatar
Default OBD1 ignition timing question
Recently I noticed that my tach started to bounce at 5000Rpm and up.
So today I borrowed a timing light to adjust it.
I connected the blue plug under the dash. So that should eliminate timing advance right?
Well, because of a bad EACV I have the revving issue. And I noticed that when the revs start to go up and down, the markings on the pulley also shift. Regardless if I jump the plug or not.
I know I jumped it right, I used a multimeter to confirm, and also my CEL does all the right things as it's supposed to when you jump it.
What would make the marks shift like that still?
It's making it almost impossible for me to set the timing.
Old May 2, 2006 | 03:32 AM
SETI20's Avatar
Default Re: OBD1 ignition timing question (SETI20)
nobody any clues?
Old May 2, 2006 | 04:33 AM
crx_88_si's Avatar
idle should be steady when checking timing. unplug the iacv for the test.
Old May 2, 2006 | 04:47 AM
YasRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">I connected the blue plug under the dash. So that should eliminate timing advance right?
yes
disconnect the iacv when you adjust the timing , check yuor rpms make sure engine is 100% warm (fan kicks on)
Old May 2, 2006 | 08:48 AM
SETI20's Avatar
ok,....so it's normal for the mark to shift when it revs? I thought that would be eliminated when you jumped that plug.
...I'm using a real simple strobe hooked up to the cil#1.
fenix4o9
Jan 23, 2010 07:40 PM
jchrm80
Dec 22, 2007 05:14 PM
Project_99Hatchback
Mar 30, 2006 05:05 AM
jeef84
Apr 8, 2005 12:37 PM
93SSPHatch
Jan 19, 2003 11:32 AM
