Oil Pressure Gauge Hook Up .. F22
Old Apr 30, 2006 | 02:49 PM
standbackimapro's Avatar
Default Oil Pressure Gauge Hook Up .. F22
i have a 90 accord with an f22, and i wanna install this oil pressure gauge, Where can i run the line from the gauge to get the oil pressure?
Old Apr 30, 2006 | 04:22 PM
i_kick_turtles's Avatar
Default Re: Oil Pressure Gauge Hook Up .. F22 (standbackimapro)
You will need to run a brass t from the hole where the oil pressure sender goes. This will allow you to keep your stock sender, while adding your aftermarket gauge. Search for some how to turbo guides and use the same procedure you would to install oil feed lines.
Old Apr 30, 2006 | 06:07 PM
Wheres the Oil Pressure Sending unit located?
Old Apr 30, 2006 | 06:24 PM
92ehatch's Avatar
Default Re: (standbackimapro)
just above your oil filter.
wait till its time to change your oil, drain the oil, take off filter, whala, sending unit directly obove it. 15/16 socket to remove it.
Old Apr 30, 2006 | 07:22 PM
raceACCORDingly's Avatar
http://tunertoys.zoovy.com/product/OTODK
or a oil filter sandwich adapter.
EFsideways
Jan 1, 2008 01:52 PM
TylerC161
May 29, 2007 12:00 PM
CivicMike
May 26, 2005 09:34 AM
W O T
Jan 29, 2005 08:01 PM
krshultz
Mar 22, 2002 02:41 PM
