need b18c1 motor layout - questions about fmax install
Anyone have a diagram of a b18c layout labelling the parts of the engine?
most importantly need to know which/where the oil pump is.
also could use some help with some pics/explanation how the IC pipes come together. using fmax kit with FMIC.
lastly, if anyone has the real install instructions for an Fmax kit, please im me. (not the crap they have on their website)
thanks in advance...
oil pump is on the drivers side of the block on the bottom where the pan meets, behind the timing belt cover. it also screws into the oil pan mount flange. from the way you posed your question I advise you not to remove it yourself, no offense intended.
J1A1H
Jul 6, 2006 07:06 AM
Total'd GSR
Feb 2, 2002 11:19 AM
