OBD2 to OBD1-Motor swap
Old Apr 28, 2006 | 11:04 PM
DFW's Avatar
DFW
Default OBD2 to OBD1-Motor swap
I have a 2000 civic non vtec (i think it's obd2b) and going to buy an obd1 gsr swap. Is the 99-00 civic si wireing harness the only one that will work?
I was searching and found people were using obd2 to obd1 converter? Can I get one of those or only the si one will work?
Modified by DFW at 2:17 AM 4/29/2006
Old Apr 28, 2006 | 11:52 PM
VRD^sam's Avatar
Default Re: OBD2 to OBD1-Motor swap (DFW)
the 99-00 Si harness will work fine but you will need the obd2b to obd1 converison harness...
Old Apr 29, 2006 | 12:00 AM
DFW's Avatar
DFW
Default Re: OBD2 to OBD1-Motor swap (jdm.mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm.mike &raquo;</TD></TR><TR><TD CLASS="quote">the 99-00 Si harness will work fine but you will need the obd2b to obd1 converison harness...</TD></TR></TABLE>
So I need both?
Old Apr 29, 2006 | 12:54 AM
strictly.business's Avatar
Banned
you need any vtec obd1 harness, or use your obd2 harness, run vtec wires from your ecu inside the car to the motor and use an obd2 to obd1 conversion harness to use the obd1 ecu. an obd1 harness would be ideal but its a paiiiiiiiiiiinnnnnnn in the ***.
Old Apr 29, 2006 | 01:57 AM
VRD^sam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">
So I need both?</TD></TR></TABLE>
Will what you can do is use your Harness and just wire up knock, and vtec wires...I did my wiring in my 97 Ek with my gsr swap in 30minutes max...its not that hard to pin and wire up the konck and vtech...but it'd be easier if you had a 99-00 Si harness or a 99-00 Ex harness...
Old Apr 29, 2006 | 01:58 AM
VRD^sam's Avatar
Default Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">you need any vtec obd1 harness, or use your obd2 harness, run vtec wires from your ecu inside the car to the motor and use an obd2 to obd1 conversion harness to use the obd1 ecu. an obd1 harness would be ideal but its a paiiiiiiiiiiinnnnnnn in the ***.</TD></TR></TABLE>
no you dont want to use a obd1 harness...way to much work and it'd just make you more stressed out...just use your old harness and wire up vtec and knock etc...
Old Apr 29, 2006 | 07:03 AM
DFW's Avatar
DFW
Default Re: (jdm.mike)
Alright I'll try to find an 99-00 si harness or ex harness, if not I guess I'll use my stock one wire up the other wires.
THanks
Old Apr 29, 2006 | 08:06 AM
DFW's Avatar
DFW
Default Re: (DFW)
Is there anything else I need to do besides getting a 99-00 si/ex harness and mounts?
Old Apr 30, 2006 | 07:37 PM
VRD^sam's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Is there anything else I need to do besides getting a 99-00 si/ex harness and mounts?</TD></TR></TABLE>
nope that should be it...just mounts and a harness if you dont wanna reuse yours
Prudz_lude
Dec 3, 2008 06:41 PM
johnnys_ek9
Nov 29, 2006 08:15 PM
DFW
May 2, 2006 07:44 PM
danxdan
Jul 13, 2005 03:37 PM
danxdan
Jun 9, 2005 04:46 PM
