injectors or fuel filter
Old Apr 28, 2006 | 09:43 PM
Duch's Avatar
Default injectors or fuel filter
I have a USDM 99 ITR in my civic, and recently when under 4000rpm or light throttle, theere is a sputtering, coughing, and when in neutral the car will slowly die. It starts back up, and evrything seems fine, until you go underway again. Wondering if it would be the fuel filter or the injectors to replace, or if it would be anything else. On the way home, I bought injector cleaner, and it helped a bit, but the coughing and sputtering is still present, but not as much. thanks
Old Apr 29, 2006 | 02:19 AM
jdmsi1320's Avatar
you might not be getting enough fuel
Old Apr 29, 2006 | 06:51 AM
Soccerking3000's Avatar
Default Re: (jdmsi1320)
i agree get a new fuel filter and also what ecu are you running? is it tuned?
Old Apr 29, 2006 | 07:19 AM
scrappysofly's Avatar
Default Re: injectors or fuel filter (Duch)
i would check everthing filter pump injectors
Old Apr 29, 2006 | 09:13 AM
Duch's Avatar
Default Re: (Soccerking3000)
it is all stock. Stock computer (p28) but running through a VAFC, but with no changes as of yet.. I bought the car the way it sits, and havent had a problem until now. Where is the fuel filter, on the line or is it attatched to the sump? So along the line or in the tank? thanks
Old Apr 29, 2006 | 08:09 PM
Duch's Avatar
Default Re: (Duch)
also another question for a first time honda owner. what is the rubber hose off of the back of the intake manifold. it has been blocked off, and a cansiter has a line cut, looks like same line, and other side of canister( by firewall) connects to line underneath car, which is by, or is the fuel lines.
Old Apr 30, 2006 | 06:22 AM
Default Re: (Duch)
thats probably the evap canister
Old Apr 30, 2006 | 09:23 PM
Duch's Avatar
what is the evap canister used for? good to hook it back up or no?
Old May 1, 2006 | 12:12 PM
Duch's Avatar
Default Re: (Duch)
Old May 1, 2006 | 01:43 PM
YoungKadafi's Avatar
yes, get a helms and hook it up STAT!
Old May 2, 2006 | 07:58 PM
Duch's Avatar
Default Re: (YoungKadafi)
i recently took the vac line from the intake man to the fuel pressure regulator, and replaced it. the sproblem has seemed to go away.
Old May 3, 2006 | 05:19 PM
Duch's Avatar
Default Re: (Duch)
**** 100km's later, started doing it again.. lol.. eventually i will figure it out.. unless someone can help me before i eventually stumble on the right answer lol
Simon Szuba
Aug 3, 2017 12:59 PM
SPORT INJECTION
Sep 19, 2011 05:58 PM
sohctodohc
Mar 19, 2009 02:31 PM
revhardallday
Dec 12, 2008 01:39 PM
crj_lll
11
Mar 22, 2006 07:39 AM
