Finer filtering fuel filter? Injectors clogging
Got a 94 Integra on a trade and it's having one issue. After you drive the thing for maybe a hundred miles, it starts missing and drives horribly.
If I pull the fuel rail and get the injectors out, they are clogged with fine crap. What the heck. Keeps happening. Clean them out, and your good to go for a while, but it happens again. Super fine particles. I've never had this happen before in any Honda I've owned.
what do you guys think I should do? Is the fuel filter bad? Would that normally catch these particles? Obviously it's getting through... so if it were clogged... that's not the issue I guess?
Is there a finer fuel filter I could throw on to catch this stuff before it gets to the rail and injectors??
Thanks for any advice.
Re: Finer filtering fuel filter? Injectors clogging
Yeah, i'm assuming it's particles in the tank... i havent looked in there to see.if its rusty or not. Its a southern car, no rust anywhere, not that that means the inside of the tank wouodnt rust i guess. I know the previous owner whos had the car for years as his daily, and this problem just started before I got it. Just wondered if there was such a thing as a super finer then oem filter.I could buy from somewhere? Any recommendations or links?
has this happened to anyone else?
I would start with throwing a new OEM or OE style fuel filter in, then pull the fuel sending unit assembly out of the tank and make sure the sock/pre filter for the fuel pump is still attached. While you have that out you can look around in the tank a bit and see if it has junk floating around in it.
The only time I have really heard of this happening is when the lines (rubber/steel) or the tank start to deteriorate and it can cause all kinds of issues. But this is usually on cars that sat for long periods of time with old gas in them or they ended up getting a lot moisture in the fuel lines.
Also I am not sure if these were on OBD2 injectors only or if the OBD1 injectors had them, but there are suppose to be these little fuel injector pre filters that sit inside the injector (they slide in and out) where the top of the injector meets the fuel rail.
You haven't even replaced the filter under the hood once yet? Sounds like it has a hole in the media and is just letting everything through.
This does not happen to cars that are stock, so there is no need for special filters.
You may consider draining the gas tank if there is a lot of crud in it.
I would take the back seat out and pull the pump out. Maybe the pump is missing the sock that filters the fine particles on the bottom. You can also take a flashlight and see if there is junk in the tank.
edit: Just read 1999 Civic Si's post and I agree lol
#1 Super Guy
You could also remove the fuel-tank drain plug and drain all the fuel out to see what was lurking within. If the fuel looks clean and not full of water, pour it back in.
But definitely replace the OEM fuel filter (with OEM) if you haven't done so yet.
Lol woops, just noticed I posted this in the civic forum not the Integra forum. Habit.
there is a plug on the fuel tank?
pjr710
04-03-2010 05:59 PM
