Autozone wouldn't help my ass!
Old Apr 28, 2006 | 01:59 PM
ApolloSpeed's Avatar
Default Autozone wouldn't help my ***!
I went to Autozone and had my ECU checked cause the light was still on and still getting BAD mpg... after doing a tuneup on my '97 LX........
On the print out it shows that I have codes P0170 , and P0171. Something about bank 1 is too lean and compensation value exceeded.
So, I asked if I needed an o2 sensor.....and they don't know. So I asked which sensor they thought could be bad.....they don't know. WTF!
I don't wanna go to Honda Dealership for $95 to find out whats wrong.
What do yall think ???
Old Apr 28, 2006 | 02:02 PM
sicky's Avatar
grammer nawzi
Default Re: Autozone wouldn't help my ***! (ApolloSpeed)
Pull your plugs to see what's really wrong, they won't lie. Then change your 02 sensor.
Old Apr 28, 2006 | 02:41 PM
Default Re: Autozone wouldn't help my ***! (sicky)
I took them out.....looks pretty rich for only 4 days old.
Old Apr 28, 2006 | 04:25 PM
JDMFreak's Avatar
i would drive it to a different autozone place and see if they can help...who know you might find a guy in there that works on honda as much as you do...dont get me wrong...autozone guys know there ****...but some of them know mainly american spec cars
Old Apr 28, 2006 | 04:47 PM
schardbody's Avatar
autozone guys know their ****, c'mon, they look up parts for a living. all they do is see what code it is and recommend the sensor usually associated w/ the code.
Old Apr 28, 2006 | 04:59 PM
Bc1r6x's Avatar
Default Re: (schardbody)
make sure your use denso plugs and you have compresion
Old Apr 28, 2006 | 05:27 PM
Ross 2.0's Avatar
In a Junkyard near you.
have you gone over 150K miles? If not your car is still under the emissions warranty. The dealer WILL do the work for free.
Old Apr 28, 2006 | 06:59 PM
intevic_dx's Avatar
i work at autozone. we suck. well i dont, but most of the guys there do. thats why they work at autozone for $8 an hour instead of at a shop working on cars.
but you get what you pay for.
go to a shop and ask them to scan your code and tell you whats wrong.
stop being cheap and figure it out.
if you dont know whats wrong with your car why should we? wtf.
Old Apr 28, 2006 | 07:19 PM
stockfc's Avatar
Default Re: (intevic_dx)
well I have mitchell on demand here at home and I ran your car in it to see what the codes were. There isn't a p0170 for the lx. just p0171(lean) and p0172(rich).
Heres what it says for p0171
1. If DTC P0171 (system to lean) is set, check for:
*Insufficient fuel pump flow or pressure.
*clogged or leaking fuel feed line.
*fuel pressure regulator stuck open.
*clogged fuel filter
*clogged or air blocked fuel injector
*fuel octane level less than specification
*a deteriorated H02S-1
*MAP sensor range/performance
*Excessive EGR system flow
*proper valve adjustment
*an exhaust system leak
Repair as necessary. If no problems are found, go to step 3
thats pretty much it. Step 3 was just checking the fuel pressure and the fuel pump and all the fuel stuff. And HO2S-1 is the front o2 sensor.
Mike1995HondaPrelude
Aug 31, 2007 02:11 PM
Rudelude22
Dec 8, 2005 08:17 PM
hondagrl
Mar 30, 2004 09:16 AM
Jason kiDD
Oct 29, 2003 06:33 AM
B18C1 '96 Coupe
Dec 28, 2002 09:55 PM
