Will HX rims fit on my 2000 EX?
Old Apr 27, 2006 | 09:55 PM
US Scooterist's Avatar
Default Will HX rims fit on my EJ8?
I bought HX rims and know I'll need spacers/possibly extended lug bolts. Anyone know of a good shop in SFV or Santa Clarita area that would install them?
Melissa
Modified by US Scooterist at 9:44 PM 5/5/2006
Nintendo_Racer's Avatar
Default Re: Will HX rims fit on my 2000 EX? (US Scooterist)
yes they will fit
Old Apr 27, 2006 | 09:56 PM
Paxil4x4's Avatar
Yes
Old Apr 27, 2006 | 10:04 PM
mikey-ej7's Avatar
Default Re: Will HX rims fit on my 2000 EX? (packthis)
how much did u pay?
Old Apr 27, 2006 | 10:11 PM
4potnick's Avatar
if you have 10.3 brake you will have to mod/grind caliper bracket. if you have the smaller brakes no prob then
Old Apr 27, 2006 | 10:14 PM
Voyage34's Avatar
Default Re: Will HX rims fit on my 2000 EX? (4potnick)
the ex have the 10.3 brakes, so you will either have to grind the bracket a little bit of get a wheel spacer of about 5mm. the HX rim is a 50 offset vs the normal honda 45, so that 5mm spacer lets the wheel clear the brakes
Old Apr 28, 2006 | 06:15 AM
dohctor_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">if you have 10.3 brake you will have to mod/grind caliper bracket. if you have the smaller brakes no prob then</TD></TR></TABLE>
X2 did that with my EX
Old Apr 28, 2006 | 07:03 AM
BauleyCivic's Avatar
Risky Business
Default Re: Will HX rims fit on my 2000 EX? (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">the ex have the 10.3 brakes, so you will either have to grind the bracket a little bit of get a wheel spacer of about 5mm. the HX rim is a 50 offset vs the normal honda 45, so that 5mm spacer lets the wheel clear the brakes</TD></TR></TABLE>
Good post
Old Apr 28, 2006 | 12:09 PM
4potnick's Avatar
Default Re: Will HX rims fit on my 2000 EX? (BauleyCivic)
I just used a grinder. I rock my hx rims on my gsr from tire to time. Add some falken azenis rt615's and you have a potent lightweight setup. I think that is the best oem rim/tire combo.
Old May 5, 2006 | 02:52 PM
Default What spacers/lugnuts?
OK So I bought HX rims/tires to put on my EJ8. Any particular spacers recommended 3 mil or 5 mil? What about lug nuts?
Old May 5, 2006 | 03:20 PM
Voyage34's Avatar
Default Re: What spacers/lugnuts? (US Scooterist)
5mm spacer and oem lugnuts, the ones from stock steelies will be fine
Old May 5, 2006 | 03:38 PM
Default Re: What spacers/lugnuts? (Voyage34)
ThanQ
Old May 5, 2006 | 07:10 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">I just used a grinder. I rock my hx rims on my gsr from tire to time. Add some falken azenis rt615's and you have a potent lightweight setup. I think that is the best oem rim/tire combo.</TD></TR></TABLE>
I don't think I would call 195/60 tires on a 5.5" wide wheel on a 2700lb car "potent" More like "pathetic."
Old May 5, 2006 | 07:26 PM
ej8dude's Avatar
i had hx's on my 99ex and i had to grind down the caliper a bit...it was fine though just dont slip and hit the rotor
Old May 5, 2006 | 08:28 PM
b16a2_v-tech's Avatar
69.212.15.27
a pic of my bros 98 civic hx, as u can tell if u look at the picture 17" v.s 14" lol
http://i40.photobucket.com/alb...8.jpg
close up of the painted hx rims
http://i40.photobucket.com/alb...1.jpg
Old May 5, 2006 | 08:32 PM
Default "How much did you pay?"
$125 for a set of 4 2002 version with 30-50% tire wear left
Modified by US Scooterist at 9:46 PM 5/5/2006
Old May 5, 2006 | 08:56 PM
4potnick's Avatar
Default Re: Will HX rims fit on my 2000 EX? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">I don't think I would call 195/60 tires on a 5.5" wide wheel on a 2700lb car "potent" More like "pathetic."</TD></TR></TABLE>lol. Have you ever tried this combo? I mean you probally have, I mean who would assume? They rim/tire combo actually sit on a bit of a smaller weight car( 92 4 door civic with a d15b 15g). So what's a better OEM tire/rim package. I mean **** a hx rim weighs 11#'s.
Old May 5, 2006 | 09:21 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">lol. Have you ever tried this combo? I mean you probally have, I mean who would assume? They rim/tire combo actually sit on a bit of a smaller weight car( 92 4 door civic with a d15b 15g). So what's a better OEM tire/rim package. I mean **** a hx rim weighs 11#'s. </TD></TR></TABLE>
From a performance standpoint, I personally don't like OEM wheels at all. Sure, several of them look good, but Japanese manufacturers notoriously under-tire their cars and tend to use skinny wheels. I wish that all of my OEM Honda wheels were at *least* an inch wider.
Wheel weight is overrated IMHO. Yeah, I know all of the theory behind rotational intertia and whatnot, but in practice, saving a few pounds on each corner doesn't justify putting less rubber under the car. I'd take a 15lb 14x7" wheel over an 11lb 14x5.5" wheel any day. 225/50-14 R-comps fit much better
There's nothing inherently wrong with it though, especially if you're on a budget and/or are just looking to have some fun with a daily driven car. I used the 195/60 RT-215 Azenis on stock 14x5" CRX wheels back when I started doing HPDEs. They may not have had the massive grip and the sidewall feel of the ubiquitous 205/50-15 Azenis, but they weren't bad at all (then again my car only weighs 2100lbs). Tended to overheat easier though, and there was no gearing advantage. I'd kill for a 225/45-14 Azenis.
Eh, but I'm babbling. Man, I've missed discussing and reading about suspension/roll-stiffness/damping/brake/tire/wheel/alignment/handling theory since the RR-AX forum regulars left a month ago
Old Nov 11, 2006 | 06:32 AM
hondahybrids's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">5mm spacer</TD></TR></TABLE>
Where can i get a 5mm spacer?
Old Nov 11, 2006 | 09:03 AM
R-81 Coupe's Avatar
Default Re: What spacers/lugnuts? (hondahybrids)
yes.
EatMyVTEC :]
19
Jul 20, 2010 07:43 AM
7mile
Sep 4, 2006 01:25 PM
Suzukablue
15
Feb 27, 2006 12:28 PM
Kyles ej1
44
Mar 21, 2005 09:47 PM
MyWhiteCivic
Jan 20, 2003 06:19 PM
